03-01-2018, 01:01 PM   #1
Missing screw.
I just noticed that my K5 is missing a screw from the base.
With the camera upside-down, it it the righthand outer corner ( Just above the 5 of the K-5 on the boiler-plate. )
Any idea what size it should be? And a source for a replacement?
03-01-2018, 04:14 PM   #2
.a.t.'s Avatar
QuoteOriginally posted by crayboy Quote
I just noticed that my K5 is missing a screw from the base...
crayboy, I believe my K-7 has the same body as the K-5. In my picture below, what piece are you missing?
03-01-2018, 04:54 PM   #3
Seeker of Knowledge
aslyfox's Avatar
If I am not mistaken, from what I have read, it should be a JIS screw
Cross-head screws - a caution: - PentaxForums.com
03-01-2018, 05:05 PM   #4
QuoteOriginally posted by .a.t. Quote
Top right, just above and to the right of K-7.
---------- Post added 03-01-18 at 06:06 PM ----------
QuoteOriginally posted by Aslyfox Quote
Thanks Allen
03-01-2018, 05:29 PM   #5
Not a Number's Avatar
Just google search "micro screws" and try some of the vendors that show up. You may need to remove one of the other screws and measure it with a calipers to get the diameter and length (metric). Get some JIS drivers. Do not use Philips screwdrivers. Some of the vendors are on eBay too.
03-01-2018, 07:53 PM   #6
Maybe a local hardware store might be able to measure or try sample screws for you. Maybe even somewhere like Lowes or Harbor Freight.
You could try a screw from another location on the body to see if it fits. If it does you could seek that size. Just be careful the body or a part is not loosened too much.
03-01-2018, 08:28 PM - 1 Like   #7
.a.t.'s Avatar
Okay, so it's the screw from inside that cavity? If that's what you need, I might be able to help.
I have a stash of spare screws I've harvested from old, junk lenses. In the photo below is the original black screw from my K-7, and the silver is a spare I found.
They're not a perfect match, but the silver fits in the cavity and seems to snug down securely.
If you'd like to give the silver screw a try, crayboy, send me a private message with your mailing address and I'll mail it to you.
Tim
03-01-2018, 08:32 PM   #8
Seeker of Knowledge
aslyfox's Avatar
Tim
the K 5 is rated W R I believe
if the wrong size screw is used, would the W R of the K 5 be compromised??
03-01-2018, 09:19 PM   #9
.a.t.'s Avatar
Yeah, I don't know if WR would be affected.
For what it's worth, when I took my K-7's screw out, there didn't seem to be any gasket or sealer under the screw. And the screw is recessed a few mm inside the cavity when it's tightened down.
03-02-2018, 10:44 AM   #10
You'd be better off replacing the screw with the same time of head as the original, e.g. countersunk vs pan/button. The wrong type can put uneven stress on the screw head and/or the cover.
camera, dslr, k-5, k-5 ii, k-5 iis, k-7, k5, pentax k-5
645z, Cactus V62, Phottix Indra500 and a lot of missing hair! MDR Foto Flashes, Lighting, and Studio 45 11-23-2016 11:37 AM
Repair Cost for DA15mm Missing Focusing Screw Halide Repairs and Warranty Service 6 10-28-2016 03:50 AM
Lightroom Metadata missing for new lens gbbrowning Pentax K-1 12 05-16-2016 03:32 PM
Monopod: 3/8" adapter screw stuck on the 1/4" screw !! jpzk Pentax Camera and Field Accessories 29 04-22-2012 08:00 PM
Screw driven AF cameras. More high end = better screw drive? Reportage Pentax DSLR Discussion 13 09-01-2011 08:38 AM
All times are GMT -7. The time now is 05:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
