03-02-2018, 04:19 AM   #1
Kombivan's Avatar
Firmware question
is the 1.11v firmware for the k-m the same as the early version firmware 1.11v for the k-5?
My other k-5 has the 1.01v firmware this one currently has 1.16v (had 1.11v before upgrade)
03-02-2018, 04:30 AM - 1 Like   #2
Ex Finn.'s Avatar
I would not, under any circumstance, attempt to load FW into a camera that it was not meant for!
03-02-2018, 05:00 AM - 1 Like   #3
Na Horuk's Avatar
K-m and K-5 are very different cameras, so they have different firmware.
Firmware works with sensor, chip, buffer, etc. Even K-5II and K-5 use different firmware.
Your camera will not accept a firmware meant for another model. You can maybe trick it, but I would not recommend that. You would be very likely to damage your camera. If you don't care about that, you can do it and tell us how it went
03-02-2018, 07:11 AM - 1 Like   #4
UncleVanya's Avatar
Simple answer, no.
03-02-2018, 08:28 AM   #5
jatrax's Avatar
Absolutely not! I doubt the camera would allow you to even try but don't. Even the K-5 and K-5II have different firmware.
03-03-2018, 05:10 AM   #6
Kombivan's Avatar
I found the fault with my K5 so not thinking of this now. I just figured different models had different file names for their firmware.
03-24-2018, 09:46 AM - 1 Like   #7
Tan68's Avatar
QuoteOriginally posted by Kombivan Quote
The firmwares I have used all have the same file name even for different versions. K-1 v1.3 & v1.4 were both fwdc228b & my K-5 were fwdc209b. If this pattern is true then, yes, the K-m would have a different file name like fwdc201b or whatever.
camera, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Question about firmware updating EllenJ Troubleshooting and Beginner Help 3 06-25-2014 01:45 PM
k-5 firmware same as k-5iis firmware? grant richie Pentax K-5 2 12-09-2012 12:15 PM
firmware update question robert Pentax K-01 3 11-09-2012 12:22 PM
K-5 Firmware Update Question thejake Pentax K-5 3 01-20-2012 03:27 PM
K10d firmware update question Bokeh Pentax DSLR Discussion 14 05-24-2008 06:56 PM
All times are GMT -7. The time now is 04:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
