08-29-2018, 04:16 AM   #1
Best AF.C Setting for the K-5II
Can anybody recommend the best settings when using the AF.C on the K-5II? Thanks
08-29-2018, 04:52 AM   #2
well
I have used K-5II for more than 4 years. My recommendation is not to use and to rely on AF.C mode. The reason is that the AF areas are too large to be able to follow the subject appropriately.
When I was (occasionally) shooting any movement, I always used AF.S mode with the highest frame rate - push the AF button -> 2-4 pictures, push the AF button -> 2-4 pictures and so on ... and my success rate was quite high (around 80-90 %).
08-29-2018, 04:55 AM   #3
forensicscientist's Avatar
When shooting sports, I use AF-S, center point only.
It works for me, my style, and limited skills
Good luck....
08-29-2018, 03:47 PM   #4
Thanks. I have same observations. I just thought that maybe someone might have discovered some other technique on how to use AF.C. Thanks again.
08-29-2018, 05:10 PM   #5
clackers's Avatar
In shooting sports with a K-30, which is a vintage similar to yours, I only use single point AF-C with back button focus. Works really well.
08-30-2018, 02:05 AM   #6
I'll try that out clackers. I've tried AF.C but not with SEL. My rate of success was quite low.
08-30-2018, 02:53 AM   #7
clackers's Avatar
QuoteOriginally posted by totsmuyco Quote
I never had a problem, Totsmuyco. Why is that?
Two examples below:
08-30-2018, 03:05 AM   #8
I didn't use SEL. I used the standard focus points. I should try what you're doing, using SEL. I'm surely doing things the wrong way. Thanks for sharing.
08-30-2018, 04:35 AM   #9
clackers's Avatar
I don't understand.
Many of those focus points would not have been on your subject.
You must have got lots of shots where you've focused on strong lines around your subject or in the background.
Your homework is to choose single point and to let off many frames while smoothly tracking a moving object.
Really twist from the waist.
08-30-2018, 04:15 PM   #10
I believe you're right clackers. I still haven't gone out lately. Still busy with work. I've resolved the issues with the k-3II as suggested by C_Jones. So far, success rate with the k-3II seem okay. In line with what C_Jones suggested I thought that someone here might have some tips on some settings like C_Jones did for the k-3II.
08-30-2018, 05:12 PM   #11
clackers's Avatar
My advice for the K3-II would be different from the K5 because it can attempt object tracking with the exposure module.
For the K-5 II, you can set Expanded Area on in the menus to do a bit of this using the adjacent focus points.
But you shouldn't need anything but single point if you can track while shooting, which is the number one skill of a sports shooter.
As a drill, try to get this shot again and again with a slower shutter speed:
08-30-2018, 10:44 PM   #12
That's a great shot clackers. I still need more practice using the K-5II. Thanks
af.c, camera, dslr, k-5, k-5 ii, k-5 iis, k-5ii, k5, pentax k-5
Pentax KP - Best AF Hold setting? 08amczb Pentax KP 2 08-04-2018 01:18 PM
Setting tweaks - best practices? madison_wi_gal Pentax K-r 2 02-16-2017 02:58 AM
K-5II & AK-TTL, (K-5II stabilization error) FECOmp Troubleshooting and Beginner Help 7 02-08-2014 09:23 AM
How best to de-blur k-5/k-5II users to match k-5IIs close-enough Pentax K-5 11 12-03-2012 02:14 PM
Best K20D Setting for SMC Pentax-AF 35-70mm F2.8 hadenwc Pentax SLR Lens Discussion 3 12-29-2010 07:41 AM
All times are GMT -7. The time now is 07:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
