05-05-2019, 05:38 AM   #31
Photo Forum Moderator
photolady95's Avatar
Another question for you K-5 users, and Mark is on a short break with his wife so I don't know if he'll be able to answer me.
I had the camera set on TAV and was trying to highlight the ISO, I pushed the ISO button, but the camera would not highlight the ISO on the back of the camera. This never happened before. Anytime, I'm shooting, I could press the ISO button and it would highlight the ISO and I could use the back wheel and change it. Not so yesterday.
What's going on?
05-05-2019, 12:59 PM   #32
Senior Moderator
BigMackCam's Avatar
In TAv mode, the camera always controls the ISO setting based on your shutter speed and aperture selections, so the ISO button becomes functionless. This isn't specific to the K-5 series, but also the K-3 series. I'm not sure if the K-1 and K-1II implement it any differently, but I'd doubt it.
So, your camera is operating as it should
05-05-2019, 05:48 PM   #33
MarkJerling's Avatar
I concur with Mike.
05-05-2019, 06:24 PM   #34
I don't remember it doing that in TAV mode. I thought I could highlight it and change it from 1600 to 1250. Maybe I'm thinking it highlights in M mode and I could change ISO then.
I can change it using the info button instead of the ISO button in TAV mode.
Thanks Mike and Mark!
05-06-2019, 05:21 PM   #35
QuoteOriginally posted by photolady95 Quote
No problem. If you need me to run a check on mine, I can do.
05-08-2019, 04:09 AM - 1 Like   #36
QuoteOriginally posted by MarkJerling Quote
It was what I remembered it was, I could change it in M mode but not in TAV except with the info button, I could lower it. Just had a brain freeze is all.
05-18-2019, 03:40 AM   #37
I got another question. I did warn you I'd be back with more, didn't I?
I turned the camera on yesterday, setting was in M mode, I knew I should be able to change ISO setting in this mode but no matter how many times I tried, I couldn't get it to highlight the ISO with the ISO button. Then I noticed a strange object up on the back LCD, it showed what looked like and asterisk symbol. So in desperation, I turned the camera off and back on again, and this cleared the object from the back LCD. I still don't know how it happened, I hadn't changed anything, made no settings different from my shooting yesterday.
Can anyone tell me what that was and how it got there?
05-18-2019, 07:42 PM   #38
I've never seen that before. In what part of the display was the asterisk?
05-19-2019, 04:00 AM   #39
On the back LCD, on top along the row where it shows SR, AF.S, Spot meter and Battery level, this asterisk, showed up on the left side, just to the right of M where it depicts which mode I'm in.
And I've never seen it before either.
05-19-2019, 04:34 AM   #40
Aha! Page 121 of your manual. You've pushed the AE-L (Exposure Lock) button. That illuminates the asterisk and explains why you can't change the setting.
05-19-2019, 04:39 AM   #41
pschlute's Avatar
You can use the info button to change the limits for ISO for any mode that uses auto ISO including TAv. What you cannot do in TAv mode is to select an ISO for the camera to use. In TAv mode the camera will select it's own ISO value within the limits you have set for it.
The asterisk symbol usually indicates exposure lock has been activated. I suspect you pressed the button on the camera. When exposure is locked you cannot change any parameter until you either take a picture; press the exposure lock button again; or let the lock time-out, usually a few seconds.
05-19-2019, 05:00 AM   #42
Page 121, of a manual I've never read any of except to see how to put the batteries in K-x
But the AE-L button sits on the back right side of the camera and I could have pushed it when I picked up the camera to turn it on.
Thanks Mark.
05-19-2019, 05:32 AM   #43
Larrymc's Avatar
Thanks Mark.
If you have your sound effects set to on then you should hear a beep similar to the focus lock beep as soon as you push the AE-L button with the camera on. You should be able to set up the sound effects in the wrench menu with selectable options to turn certain sound effects on/off.
05-19-2019, 05:37 AM   #44
QuoteOriginally posted by Larrymc Quote
I don't think I'd hear that. My hearing isn't all that good and my hearing in left ear which is closet to the camera is totally blank in the hearing department. But thanks for the tip, if I ever get a hearing aid so I can hear better.
05-19-2019, 04:07 PM   #45
Thanks Mark.
You're welcome. The manual makes good bed-time reading. It's only 383 pages and filled with stuff I forget all the time!
AF Spot mode: hidden fact revealed - AF point is 30% smaller than in "select" beholder3 Pentax DSLR Discussion 17 09-14-2018 12:15 AM
Question: is the KP AF in s-af mode better than the K3"s? Chris Mak Pentax KP 17 11-14-2017 06:03 AM
Select AF point(s) vs. single (spot) point ... any difference in accuracy? jpzk Pentax K-3 35 05-06-2016 05:31 AM
AF point selection in M Mode on K-7 voyager13 Troubleshooting and Beginner Help 6 04-07-2013 11:06 PM
K-7 question: Focus Mode Lever - AF Point Switching Dial romualdinho Troubleshooting and Beginner Help 2 11-19-2009 04:08 PM
All times are GMT -7. The time now is 05:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
