11-02-2018, 11:52 AM   #1
K-5 II memory card issue
All,
I have now had my K-5II give me error messages with two separate 128gb SDXC cards, wherein after a certain point, they will not record any further images, despite not nearly being full. Does the firmware have a 64gb limit? Any input would be appreciated. Thank you.
11-02-2018, 12:02 PM   #2
QuoteOriginally posted by toukan Quote
If it does, I don't believe it is documented. Which brand card are you using?
11-02-2018, 12:22 PM   #3
they are both the Micro Center store brand. I have used a dozen of their brand cards before and never had an issue. They also both seem to have given the error after a certain number of images were on the card. When i have both in front of me, i will look at the exact number of images.
here is a link:
Micro Center 128GB SDXC Class 10/UHS-1 Flash - Micro Center
11-02-2018, 01:24 PM   #4
Docrwm's Avatar
No the 5 series is rated for SDXC cards so 128 should be fine. I've had issues with cards when they weren't formatted in camera.
11-02-2018, 04:26 PM   #5
mauri's Avatar
" I've had issues with cards when they weren't formatted in camera."
This.
11-04-2018, 05:32 AM - 1 Like   #6
Oldbayrunner's Avatar
Agreed you should only format camera cards in the camera. Even then there can be times the cards mess up so a low level format may straighten out the problem. For this the SD Association has a software made for formatting the cards on a computer without damaging a partition the camera uses on the card....OK try this....
Download this software SD Memory Card Formatter - SD Association
Look for and run the low level format. Then try your card in the camera again and see if it errors.. If so then your cards are bad.
camera, dslr, ii memory card, k-5, k-5 ii, k-5 ii memory, k-5 iis, k5, pentax k-5
Penta k3 issue writing to card or card issue? Andrewlang Troubleshooting and Beginner Help 19 10-29-2018 06:27 PM
Memory card not formatting on my K-3 ii Elizabeth Troubleshooting and Beginner Help 7 01-27-2018 01:27 PM
SD card does not click in place and Memory Card Error barbriba Visitors' Center 2 05-03-2017 05:17 AM
SanDisk memory card works on PC but says 'memory card error' in K-S2 kudzx Pentax K-S1 & K-S2 9 02-15-2017 09:03 AM
Pentax K5 II Recording to Memory Card Too Slow 64t0 Pentax K-5 7 01-31-2017 07:16 AM
All times are GMT -7. The time now is 04:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
