01-19-2019, 05:36 PM   #1
Light Meter - TAv Mode
Does anyone know if it is possible to turn on the light meter in TAv mode for the K-5ii?
01-19-2019, 07:53 PM   #2
If you’re asking whether it can shoot in TAv mode, yes.
01-19-2019, 07:59 PM   #3
I am asking if you can have the light meter display in the Viewfinder when in TAv mode.
01-20-2019, 02:07 AM   #4
Fogel70's Avatar
You will only see the EV-bar if setting exposure compensation to anything else than zero.
01-20-2019, 02:40 AM   #5
pschlute's Avatar
QuoteOriginally posted by sutherland Quote
But the light meter would always display 0
What exactly are you trying to achieve ?
01-20-2019, 07:26 AM   #6
I find it helpful to know how far off I am from 0. I don't mind under-exposing the image in certain settings in exchange for faster shutter speeds to account for motion blur (not camera shake).
01-20-2019, 08:34 AM - 1 Like   #7
pschlute's Avatar
Yes, but in TAv mode the camera will use ISO to give you a "correct" exposure ie "0" centred on the light meter. If you want to underexpose the shot then use exposure compensation when I understand the meter will show in the viewfinder (I don't have the K5 so cannot check myself)
or is your question related to a limit you have set for auto-ISO ?
01-20-2019, 07:13 PM   #8
If you’re in TAv mode, the K-5 will only show you the ISO value it has set (in place of EV+ or -) to give you the “correct” exposure based on your set shutter speed and aperture. If you use exposure compensation, you will see the scale simply showing the amount of compensation that you have indicated. If you’ve turned the electronic level on, you’ll see that instead of the EV scale.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, light, light meter tav, meter, mode, pentax k-5, tav
What is the purpose of TAv Mode on Pentax DSLRS? Theov39 Pentax DSLR Discussion 31 03-26-2018 02:18 AM
K1000 Light Meter Calibration - Aperture has no effect on light meter? appalachian1 Pentax Film SLR Discussion 5 03-14-2017 07:08 PM
Manual mode on my K10D is acting like TAv mode Love my K10D Visitors' Center 9 11-06-2013 11:44 AM
All times are GMT -7. The time now is 09:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
