03-21-2019, 09:03 AM   #1
K5 and K7 bottom compatibility?
Hello there!
So i got a K5 for a bargain upgrading from a K30. I'm loving the camera, however, it has an ugly ding on the bottom plate which I reckon might also endanger the weather resistance of the whole camera.
I am willing to replace the bottom cover myself, but a part for the K5 is nowhere to be fount on ebay, I could only find a cople for the K7. From what i read the bodies are almost identical.
Can anyone tell me if the K7 bottom plate will fit on the K5 body? Preferably someone who has both the bodies and can make a side by side comparison.
Thank you!
03-21-2019, 09:19 AM   #2
sergysergy's Avatar
Well, the grip is the same so it would make sense.
03-21-2019, 09:29 AM   #3
rangercarp's Avatar
If the weather sealing is your concern you may want to put a dab of silicone on the ding and call it good. Replacing the bottom plate quite possible could impact the weather resistance. Water proof watches are often no longer water proof after the battery is replaced. I don't think I would take the chance.
03-21-2019, 10:02 AM - 1 Like   #4
tvdtvdtvd's Avatar
QuoteOriginally posted by rangercarp Quote
Really?(*) Seems a critical design flaw. Who knew all those insanely pricey bracelets were one time use only.
* - Asked genuinely by the man who gave up wearing watches a long time ago. I hate the sensation of having my
wrist hairs plucked out.
Sorry I can't answer the original question. If they share the same grip that would suggest a strong possibility
but no guarantee. Perhaps Ricoh support might be able to confirm?
03-21-2019, 01:41 PM   #5
I know the battery doors are the same as i bought a used K5 door (ebay) for a K7 a few years ago. If it were me and the damage isn't too bad, I would try to silicone repair mentioned. Good luck!
03-22-2019, 06:49 AM   #6
rangercarp's Avatar
QuoteOriginally posted by tvdtvdtvd Quote
The watches I wear have batteries that typically last for three or four years, often more. By that point the watch is probably pretty beat up anyway.
03-22-2019, 10:12 AM   #7
I already removed the bottom plate to check for damage... oops!
No really, I dont think I endangered the weather resistance in any way, because there is an insulation strip running along the edge of the plate.
BUT, on a closer inspection, i noticed tiny dust specs on the corner of the lcd adjacent to the damage(dust intrusion), so I guess the ding HAS damaged the WR. I gues the silicone option is not that bad. after all its not like I will dissasemble the camera on daily basis... and no, id doesnt look that bad either!
thanks guys!
05-23-2019, 07:22 AM   #8
A bit later, never-the-less:
The bottom plate of the K5 and K7 are interchangeable. Just that the logo will say K7 then, thats all.
bodies, bottom, camera, dslr, k-5, k-5 ii, k-5 iis, k5, k7, k7 bottom, pentax k-5, plate
Nature I believe I see at the bottom, a bee's bottom. Tonytee Post Your Photos! 1 08-13-2018 12:34 PM
Travel Lake Bohinj-Bottom to top to bottom lukulele Post Your Photos! 4 04-25-2014 09:43 AM
Pentax K7 Bottom Terminal Cap A.M.92 Pentax DSLR Discussion 2 01-22-2011 06:01 AM
Distance from bottom of the k7/k5 to the lens mount. omega leader Pentax K-5 8 11-17-2010 03:58 AM
MX bottom plate compatibility RickM Pentax Film SLR Discussion 4 11-05-2009 04:28 PM
All times are GMT -7. The time now is 07:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
