10-27-2010, 07:14 PM   #16
Eruditass's Avatar
QuoteOriginally posted by egordon99 Quote
You're missing the point. You don't need to "cope" with ANYTHING you don't want. If you need a faster shutter speed to accomplish the image you have in mind, go into M and use a faster shutter speed!
Even Tv should work, which is what one would naturally use to get the desired shutter speed.
10-27-2010, 08:13 PM   #17
SpecialK's Avatar
I remember "X" mode from my K10D. It seemed like a waste of space on the dial. M mode with the shutter set to 1/180s would accomplish the same thing, PLUS let you quickly use a slower shutter if you desired.
Of course, but this saves one step in making an adjustment :-)
10-28-2010, 05:27 AM   #18
QuoteOriginally posted by Eruditass Quote
Except Tv would set the aperture wide enough to expose for the ambient. In low light situations, this is probably going to be wide open unless you have the ISO jacked up or a low-light prime.
I guess if you don't care about DOF, you could use Tv set to 1/180s.
I prefer to control shutter speed, aperture and ISO myself, and let ETTL figure out the flash power when I have the flash on the hotshoe (off-camera I set the flash power manually)
50mm, camera, exposure, f2.8, f3.5, flash, k-7, k-r, kr, pentax k-r, shutter, value
cannot adjust shutter speed in manual on K-x.. ARSLONGA VITABREV Troubleshooting and Beginner Help 14 03-25-2010 10:32 PM
Shooting Raw but want to adjust EV 1/3 darker? rdrum76 Pentax DSLR Discussion 14 12-28-2007 11:41 AM
how to adjust exposure and aperture with buit-in flash on K10D itzalak2 Pentax DSLR Discussion 5 11-12-2007 08:57 AM
Problem shooting with flash on ericmjl Pentax DSLR Discussion 1 10-09-2007 02:43 AM
Has your Pentax Flash failed? Poll chedoy Pentax DSLR Discussion 30 09-04-2007 01:40 PM
All times are GMT -7. The time now is 02:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
