11-02-2010, 12:10 PM   #1
kent's Avatar
K-r ISO test
Straight jpeg from camera. K-r was with kit lens.
ISO 200
http://www.thepicturehost.com/pictures/ecce45f8e36e07cd98642c7c64def65d.jpg
ISO 400
http://www.thepicturehost.com/pictures/cb13505a71d40a33139b97f03b8b2fe1.jpg
ISO 800
http://www.thepicturehost.com/pictures/6ce9eabe6f37fac0141f70e71323b977.jpg
ISO 1600
http://www.thepicturehost.com/pictures/ad66565d31eade99830f302b8b8f9e40.jpg
ISO 3200
http://www.thepicturehost.com/pictures/0a102d8de499ed4369abf084d98224fa.jpg
ISO 6400
http://www.thepicturehost.com/pictures/6acfd495d425482a1c06b30699f5f215.jpg
ISO 12800
http://www.thepicturehost.com/pictures/dfbb3fd9d048ab62e823b3889d9e54f2.jpg
Keep in mind that site has compressed pictures and deleted exif. By the way, have you ever seen so many k-5's?
11-02-2010, 12:38 PM   #2
Raylon
Guest
I am honestly slightly surprised how noisy those 6400 and 12800 shots are.
But all the shots are in super bad lighting and underexposed so it's really hard to tell anything.
11-02-2010, 12:45 PM   #3
kent's Avatar
Exposure is ok
11-02-2010, 01:31 PM   #4
QuoteOriginally posted by kent Quote
Exposure is ok
How can you be so sure? You have any idea of what was done after the pictures were taken?
I'll reserve judgement till after a reputable (like DXO) site has done some testing.
11-02-2010, 01:41 PM   #5
Fl_Gulfer's Avatar
You really trust DXO with any camera other than Nikon or Canon?
11-02-2010, 01:52 PM   #6
Raylon
Guest
QuoteOriginally posted by Fl_Gulfer Quote
Well seeing how the Kx and Kr are 20 and 21, respectively, yes, I do. If they truly didn't care about Pentax they simply wouldn't review them. Also they wouldn't rank a $500 camera about many other higher priced CaNikons.
11-02-2010, 01:55 PM   #7
jpzk's Avatar
It looks not bad at all actually.
Whether this is because of the proper exposure or not, I would be tempted to say that those images, JPEG's at that, at quite acceptable at the higher ISO's.
Have you any RAW tests?
JP
11-02-2010, 02:35 PM   #8
kent's Avatar
No, only Jpegs.
11-03-2010, 02:36 AM   #9
High ISO JPEG out of camera, if you must use them, have to be on Strong NR, otherwise they look ugly.
K-R/ K-X is no different, just that the bar has been pushed up 1 to 2 stops.
Even the 7D, yesterday's High-ISO APS-C leader, doesn't look good with OOC JPEG at ISO6400.
Most of the wondrous High-ISO shots you see from the latest bunch of Pentax cameras were taken RAW and processed through NR software. And they DO clean up beautifully.
11-03-2010, 08:37 AM   #10
Biro's Avatar
Well, here's a quick RAW comparison test between the K-r, K-x and K-7 from DxO. They haven't done the K-5 yet. High ISO results for the K-r are just a bit suprising to me.
DxOMark - Compare sensors
11-03-2010, 09:05 AM   #11
seems like the KX kicks their (K7, Kr) asses in the IQ dept according to the dxo tests
11-03-2010, 11:31 PM   #12
QuoteOriginally posted by dylansalt Quote
Looking at the detailed dXOmark graphs, and not just the one-liner ratings, I have difficulty seeing any daylight between the K-X and the K-R.
Both of them are, of course, significantly better than the K-7 in most departments.
The K-R basically kept the K-X's Image Quality, but improved in many other areas of usage - AF speed, Video, FPS, HDR, NR customability, AF adjust menu, etc.
camera, iso, k-r, kr, pentax k-r
K-x versus K20D ISO test rparmar Pentax DSLR Discussion 68 08-26-2010 02:19 PM
K-x High ISO Test Shots :- ) wll Pentax DSLR Discussion 9 11-09-2009 12:43 AM
K-7 iso 3200 test shots. pcarfan Pentax DSLR Discussion 87 09-06-2009 10:47 PM
K7 Low ISO Test Shots UK-K20-User Post Your Photos! 9 06-19-2009 09:50 PM
k10d vs k20d ISO 1600 test PentaxPoke Pentax DSLR Discussion 9 05-11-2008 02:36 PM
All times are GMT -7. The time now is 03:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
