Originally posted by scastilloc Muchas gracias, por el tip, pero estos dos botones parecen estar bien, todo parece indicar que es una cuestion interna de que el flash no carga. Ya que si detecta que el fash esta desplegado y no permite tomar la foto ya que queda esperando a que se cargue el fash y como nunca llega esta señal no toma la foto.
Gracias.
Saludos.
Alguna otra idea?
If I understand correctly (the translation) your camera is working as expected, but only when you engage the flash it does not let you to make a photo while the flash is charging.
This is normal behaviour and is meant that when you want to use a flash the camera waits till it is fully loaded. However, I don't want to wait for the flash to charge either, maybe something interesting will happen just then.
To enable shutter release while flash is charging go to menu C3 chapter 16 and choose option 2.
cheers,
d
