Originally posted by jlaubza I have a KX that sometimes generates the double image blur at 1/60s i.e. the problem that is denied by many but acknowledged by those of us who have it.
The KR is virtually the same camera in mass and shape but with a faster shutter, something has changed in the shutter mechanism.
Has anyone so far reported or found a double image blur issue at 1/60s?
1. In the several months that I've flogged my K-x, I can't recall being plagued by the issue you mention, other than what I can definitely put down to PEBKAC that is.
So not confirming or denying that it exists.
(Anyone know what is the PEBKAC equivalent for the camera world?)
2. I was unaware that K-r has a faster shutter, only that its specs run from 1/6,000th through 30s, to Bulb, same as K-x. And of the two I can't say that my up-yours finger senses any real difference in the respective shutter buttons. Well yeah... maybe the K-r is a bit 'smoother' or 'softer' and is slightly quieter - but that might just be new factor assessment at work, a placebo. Do shutter mechanisms get clunkier over time? Being mechanical componentry I expect so even if only in a small way but normally decay wouldn't be noticeable due to slow familiarisation by the user.
Or did you mean some other definition of "faster"?
3. Yes and maybe. As *it happens, I found one only pic I took yesterday with a new K-r at 1/60 is double-imaged, blurred, ghosted or whatever.
It was a pic of mostly text on my PC monitor so easy to see the duped background, and I can't easily relate a known cause to why it should have came out that way.
Others I took at same time that happened to be 1/60th shutter too didn't double, although some are noticably movement-blurred or off focused, and for want of trying I haven't been able to duplicate the problem on demand since reading your post.
So, a one-off accident maybe? Sorry if that's no real answer to your query.
.R.
