12-11-2010, 06:17 PM   #1
[langtitle=es]Flash National PE-204 en K-R[/langtitle]
Hola, he encontrado entre el kit fotografico antiguo de mi papa un flash NATIONAL PE-204, de una antigua pentax k1000, ya que el flash de mi nueva K-R dejo de funcionar, quisera saber si alguien sabe si puedo utilizar de forma segura este flash en la K-R.
aludos.
12-11-2010, 06:48 PM   #2
stormcloud's Avatar
i would doubt it - the trigger voltage on such an old flash will most likely be to great for modern cameras - you can get a volt meter out and check it though
12-11-2010, 07:15 PM   #3
bogiesbad's Avatar
That flash is also known by Panasonic.
Here is a list and the Panasonic/National 205 is on it and considered unsafe so I would say: No.
QuoteOriginally posted by scastilloc Quote
aludos.
Right back atcha.
12-11-2010, 07:15 PM   #4
I found on the web that the National pe-205 is listed as 120 Volts. Too high a trigger voltage, it will destroy the flash circuit.
12-11-2010, 07:50 PM   #5
Si de hecho ese flash trae la opcion de conectarlo directamente a la corriente electrica de 120 o 220 V sin necesidad de utilizar pilas.
Muchas gracias, me fue util la informacion, le han salvadola vida a mi K-r.
Muchas Gracias.
12-16-2010, 01:54 PM   #6
If you wish to keep it and use that flash, you might be able to use an optical remote-trigger on that flash, triggering it with the built-in K-r flash or a show flash on the K-r that would work with the new(er) DSLR cameras. This on-camera flash would trigger the external flash via the light from the flash.
camera, el, flash, k-r, kr, mi, pentax k-r, si
Problema con flash K-r scastilloc Pentax K-r 5 04-06-2011 11:07 AM
Ayuda con estructura de flash K.r scastilloc Pentax K-r 3 12-08-2010 10:10 AM
Flash af-360FGZ et Pentax K-7 Granby62 Flashes, Lighting, and Studio 3 09-13-2010 07:42 AM
Using Sekonic Flash meter with Pentax 67 dng88 Pentax Medium Format 4 06-09-2010 06:10 AM
All times are GMT -7. The time now is 10:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
