Originally posted by LIJ I just found it to be an interesting fact that the day before the earthquake, they released the update for the more expensive models. Of course, Pentax must have the capability to work on several projects at the same time, but I do believe that their top priority is, and will always be, the more expensive models.
I think the whole earthquake thing is a "red herring" (a fact which diverts attention away from an item of significance).
Yes, an attempt at fixing the auto-focus was made on the expensive models, but there is a big difference between those models and the K-r. The K-5 has
SAFOX IX+ while the K-r has
SAFOX IX. No plus. The plus is an additional sensor that many believe
was added to specifically compensate for this very problem! IF this is true, then that means Pentax knew all along that the K-r had this issue and they went ahead and released it anyhow with no documentation to warn the buyer of the limitation. This would also mean that the problem is
hardware related. I for one am no longer convinced that a miracle firmware is on the way.
