Originally posted by Sekul i did the same, tried a lot of setting, but my final setting is actually very similar to default.
I enabled iso 100
Set iso steps as Ev steps
noise reduction: 800 off, 1600 weak
auto iso: 100 - 1600
auto WB: A+2
and the green button is now optical preview
im very happy with that
i tried fine sharpening, but promote noise a lot
I wonder if setting Auto WB to +2 is a good idea? WB is dependent on the light color and auto WB selects it automatically. It's stands to reason then you're changing all your WB settings doesn't it?
Maybe I just don't understand.
I've started using custom white balance. I printed off a couple of shades of gray one @18% and the other at 12% and experimented in differing types of lighting.
I found that at 18% gray I get very realistic colors in all the lighting I've tested. I also found setting a custom WB takes only a few extra seconds.
I placed a white border around the gray so that I'm able to get an accurate focus and save it on my bag. I also saved it to the computer so that I can print it off again as needed.
It's pretty crude but works quite well.
