01-29-2011, 09:10 PM   #1
cropping with the Digital Camera Utility
Having hard job cropping images in Pentax DC Utility V4.30 on a mac.
I can move the cropping box and get left hand top to be in the right place
And
I can get the right length of the cropping box
but
getting it to be the right width - duh - I can not. Must be a simple answer
hope you can assist
mt
01-30-2011, 12:29 AM   #2
hcc
hcc's Avatar
I use PDCU on PC, but I believe that the options are very similar on Mac.
When you select Cropping, you can choose the Cropping aspect ratio:
- original
- standard size (with pull down menu)
- any given value (with selection of Width and Height)
- Undefined.
(In my setup, itis on the left. If the Cropping option does not appear, check the menu Windows and ensure that Cropping is ticked.
If you are new to this, try first the original crop aspect ratio. It will use a window of the same aspect ratio as the original photograph. That is your safe 'best bet'.
With experience you may consider to select the H:W (height to width ratio) that you want to use.
I use often Undefined when I want to zoom on some smaller part of the photograph.
Hope that the comment will assist and you like the post....
01-30-2011, 04:34 AM   #3
okay but still not getting it
Okay, used the standard sizes to get near enough to what I need.
thank you.
Now how do I apply the crop?
Do I just save it now?
cheers
mt
01-30-2011, 04:40 AM   #4
Tried saving it as - but can no longer make it a DNG file
Gotta get some sleep now and attack in the morning
thanks
01-30-2011, 04:45 AM   #5
And this time found the save as DNG but it didn't apply the crop
AHHHHH
I have become so used to intuitive software I am finding the pentax Utility frustrating because of my lack of understanding.
Can I apply the crop AND save the image as a DNG?
01-30-2011, 11:46 PM   #6
hcc
hcc's Avatar
QuoteOriginally posted by mturner Quote
AHHHHH
Two comments:
- PDCU is not the most intuitive, but the results are pretty good, among the best fee-paying softwares.
- I am unsure if you can save DNG. Typically PDCU and all other softwares are used to generate JPEG. However, you can always save the parameters (in PDCU: File/Save parameters) to get back the same setup with your original file.
02-01-2011, 03:22 PM   #7
thank you for all help
I have succeeded in saving dng out of the pentax utility and opening in photoshop 4 with camera raw and getting the image quality I need
cheers
mt
box, camera, k-r, kr, pentax k-r, utility
Camera Digital Utility 4 Rick Clark Pentax K-5 17 12-31-2011 04:13 AM
Digital Camera Utility 4 - Crash Furball Digital Processing, Software, and Printing 11 07-31-2010 03:02 PM
Need 'Digital Camera Utility 4' - CD damaged marcos Digital Processing, Software, and Printing 0 04-19-2010 04:06 PM
Pentax Digital Camera Utility 4 TeeDub Digital Processing, Software, and Printing 1 12-19-2009 04:55 PM
Digital Filters in Pentax Digital Camera Utility 4? lawsonstone Digital Processing, Software, and Printing 0 07-19-2009 04:44 PM
All times are GMT -7. The time now is 01:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
