02-22-2011, 09:33 PM   #1
Did I possibly mess up my K-r?
K-r is my first DSLR and I just got it today, I was playing around with it and in the process I ended up turning the focus ring a little bit each way... with AF turned on
Obviously I wont be repeating this I will be more observant in the future, but do you think this will cause any problems? It seems to focus fine, both MF and AF, but I am a paranoid person with new toys lol
thanks in advance for any help
02-22-2011, 09:42 PM   #2
SpecialK's Avatar
Does your lens have the quick-shift feature (the 18-55 DAL does not)? It should be OK even if not - just avoid doing that :-)
02-22-2011, 09:52 PM   #3
Right- with non-quick-shift lenses, you can still shift the focus as long as you use enough force to also drive the axle in the camera. Definitely don't do this, however, as it can break things
The kit lens that comes with the K-r is a non-quick-shift lens. If you want quick-shift, get a used DA 18-55mm II or a DA 18-55mm WR.
As a rule of thumb, DA and DFA lenses have quick-shift while others (including DA L) do not.
02-22-2011, 09:54 PM   #4
acrollet's Avatar
I've done the same thing a fair few times on my k-x, thinking I had a QS lens attached or that I had the switch on MF. No ill effects so far, I wouldn't worry about it
02-23-2011, 02:15 AM   #5
gtl
Note the DA 35mm f2.4 is the only DA lens not to have quick shift.
02-23-2011, 03:02 AM   #6
altopiet's Avatar
QuoteOriginally posted by Dave650 Quote
If the camera is still auto focusing as it should, there should not be a problem. I did exactly the same thing when I got my K-x, and 6 months and over 4500 shutter actuations later, no problem.
Next time If you want to focus manually, just remember to switch to MF
02-23-2011, 03:33 AM   #7
Is the focus ring the finely notched ring at the front?
02-23-2011, 06:30 AM   #8
altopiet's Avatar
QuoteOriginally posted by AstraNine Quote
That is the one!
02-24-2011, 08:00 PM   #9
lavascript's Avatar
Right. No harm, just try not to do that.
In the future, if you'd like to turn the focus ring without disengaging AF first, just reach over with your right ring finger and hit the lens release button, which retracts the AF driver as well.
af, camera, focus, k-r, kr, pentax k-r
Whole mess of A- 50mm f1.2 up for auction DavidWasch Pentax SLR Lens Discussion 110 11-03-2009 03:09 PM
Enjoying the mess bonovox Post Your Photos! 3 08-07-2009 02:58 PM
my user ID is a mess f8 Site Suggestions and Help 5 05-27-2008 05:29 PM
I still mess up little laker Post Your Photos! 4 04-17-2008 10:42 PM
K100D Mess up Blake Reverb Pentax DSLR Discussion 6 01-03-2008 12:55 PM
All times are GMT -7. The time now is 10:38 AM. | See also: NikonForums.com, part of our network of photo forums!
