01-09-2012, 02:36 PM   #16
oh thank you but what if it doesnt work and it makes my camera noise worse?
01-09-2012, 02:41 PM   #17
JinDesu's Avatar
There usually is an option to revert a firmware - hopefully someone more knowledgeable can jump in at this point, I don't know how to revert a firmware off my head..
01-09-2012, 02:52 PM   #18
Philoslothical's Avatar
QuoteOriginally posted by Sammie264 Quote
Updating firmware isn't going to make anything worse, provided you follow the instructions exactly, and most importantly, have a fully charged battery before starting. It's also not going to change the sound of the mirror/shutter if it's functioning as intended (but you may see other benefits). From what you described about adjusting the lens in the mount, I think you need to clean the contacts on both lens and camera. A bit of dirt on them can cause a lot of issues, and it's pretty common. A dry, clean, lint free cloth will do it. Just polish them up and see if it helps.
01-10-2012, 08:34 AM   #19
My K-R used to make that high pitched sound when I first got it but it doesn't do that anymore. Now it just sounds like a regular click.
camera, click, k-r, k-x, kr, noise, pentax, pentax k-r, shutter, sound
disable shutter noise? ukwoody Pentax K-r 7 01-02-2011 07:48 PM
K20D Shutter noise normaeinstein Pentax DSLR Discussion 13 04-07-2010 10:32 PM
KX vs. K7 Shutter Noise rockyram Pentax DSLR Discussion 29 11-11-2009 10:02 AM
K-7 Shutter noise ! Mike.P Pentax DSLR Discussion 31 05-26-2009 08:43 PM
MZ-S Shutter noise? (request) CSoars Pentax Film SLR Discussion 13 04-22-2009 08:58 AM
All times are GMT -7. The time now is 02:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
