03-03-2011, 09:38 PM   #1
lavascript's Avatar
Everybody test this for me real quick.
I noticed something odd today. First off, I have Dust Removal Start-up Action turned on. If I turn the camera off and back on a few times while in video mode with DRSU on, it eventually locks up during the DR and refuses to do anything until you pull the battery. Of course, I don't generally power-cycle my camera like that, but the first time I noticed it, I just did it once. If I turn off DRSU, it seems to be fine. Another thing is if it happens, and you DON'T pull the battery, it's apparently still pulling voltage, cuz my battery was completely dead later on.
I'm just wondering if this is a problem for everyone or just me. I mean, it's not worth sending it in, since it's VERY easy to work around, I'm mostly just curious.
thanks.
03-03-2011, 10:32 PM   #2
Ash
Community Manager
Ash's Avatar
Sounds like an 'overload' issue. I've had my K-x seize up on me once so far for no apparent reason after playback mode was turned off, and the screen went blank and the camera rendered unresponsive until batteries were plucked out and the whole thing rebooted.
03-06-2011, 11:24 AM   #3
bwDraco's Avatar
QuoteOriginally posted by lavascript Quote
thanks.
I can't seem to reproduce this problem. Can you give more specific instructions on how to reproduce the issue you've described?
--DragonLord
03-06-2011, 11:28 AM   #4
Wheatfield's Avatar
Wow, you found a way to break your camera and now you want others to do the same?
03-06-2011, 01:42 PM   #5
I remember reading somewhere to not cycle the camera like that, it would lock up the camera, and I think it was in my K200D manual. Just quit being dumb with it and it won't be a problem.
03-06-2011, 09:08 PM   #6
lavascript's Avatar
Like I said, the first time it happened, I was not "being dumb" or trying to find "a way to break [my] camera." I was in video mode, I turned off the camera, realized I wasn't done, immediately turned it back on, and it locked up. That led me to experimentation, which involved repeated power-cycles.
And DragonLord, specific instructions would be: 1) Enable Dust removal start up action, 2) Switch to video mode, and 3) Turn the camera off and on several times. I'm not talking about going all superninja on the power switch, I mean with reasonable pauses in between. A second or so.
03-06-2011, 09:51 PM   #7
bwDraco's Avatar
I still can't reproduce the problem. There may be other factors causing the issue you've described. For example, what firmware version do you have?
--DragonLord
battery, camera, k-r, kr, pentax k-r
Misc Film Pentax Zoom-90 WR: The Real World Test ismaelg Post Your Photos! 1 07-20-2010 01:38 PM
Real world TEST review K-7 Adrian Owerko Pentax News and Rumors 9 09-01-2009 10:46 AM
Industar 50-2 quick test shots Igilligan Pentax SLR Lens Discussion 11 02-16-2009 05:01 PM
Quick test shots with the Fisheye. Chako Post Your Photos! 5 12-18-2007 11:42 PM
The hang with DP review! here is a real unbias test of the k10! slip Pentax DSLR Discussion 20 12-22-2006 04:33 PM
All times are GMT -7. The time now is 05:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
