03-09-2011, 04:48 AM   #1
Question about manual focus on 18-55 kit lens
Can someone kindly confirm whether the manual focus on the 18-55 kit lens is completely frictionless or whether there is any sense of friction/grinding when in MF mode (ie. a much, much, much less resistant version of what you would get if you forced it in AF mode)? Sorry if this description is a bit poor - not quite sure how else to describe it.
The reason I ask is that the MF on the lens on the second K-r I had wasn't completely smooth (ie. there was a very light sense of friction, like something catching at very small, regular internals like a gear). I can't remember whether the first K-r and its kit lens exhibited the same tendency. (Both were returned for FF reasons while I deliberated on my next move).
In the hopes that the new firmware comes out this week (at which point I'll be sprinting back to my local retailer), I just want to know what the MF should feel like.
Many thanks.
03-09-2011, 05:22 AM   #2
Coeurdechene's Avatar
difficult to describe the feel...but here i go:
mine does not oppose much resistance..it feels almost frictionless..BUT you can hear/feel a tiny bit of friction, mine does a very very small noise..
Hope it helps...
And two last things:
- Don't worry about that. Unless you feel a strong friction/loud noise i'm sure everything is fine with the manual focus on the lens. Don't let small worries build up (just enjoy that cool piece of equipment).
- And you will probably upgrade to a better lens sometime before the kit one breaks...i'm sure you won't use it for long really. (in fact i would recomend to buy just the body ad go for the 16-45 wich can be found pretty cheap, or the tammy 17-50 f2.8 wich is a good lens with a good price.).
Hope your next body will work like a clock.
03-09-2011, 05:27 AM   #3
Verglace's Avatar
The same for me (DAL version), it is very smooth... almost frictionless, but I can hear the tiny little gears clicking in succession.
03-09-2011, 06:15 AM   #4
aurele's Avatar
i've the DAL version, it's like turning the manual focus ring around some velvet. almost frictionless. it's completely normal. if it start to make some noise or being hard, it's now that you should be carefull.
cheers !
03-09-2011, 06:54 AM   #5
Thanks all - I think Verglace described perfectly how my lens handled. Seemed to work fine to me, so glad it's not one more thing to obsess over
03-09-2011, 09:41 AM   #6
aurele's Avatar
you'll have the same feeling with all lenses that have a focusing ring without indication of distance on it.
03-09-2011, 12:15 PM   #7
With the DAL there will be significant friction if you try to manually focus while in AF mode, and this is bad for your camera. With the regular DA version, there won't be, as it features quick-shift focusing. Obviously the ring will still make a sound when you turn it, but it will be much quieter.
camera, focus, ie, k-r, kit, kr, lens, mf, mode, pentax k-r, sense
Any way to hack lenses to manual focus in AutoFocus mode (like the kit lens)? skyredoubt Pentax DSLR Discussion 8 08-07-2010 10:36 AM
Manual focus 'smoothness' question on a macro lens... nater Pentax SLR Lens Discussion 17 01-13-2010 05:57 PM
manual lens focus question kjfaust Pentax DSLR Discussion 11 05-16-2008 05:20 PM
Question about using manual focus lens. XMACHINA Photographic Technique 3 02-13-2008 08:23 AM
Question on Ist-D focus confirmation on 3rd party manual K lens brainanta Pentax DSLR Discussion 13 03-21-2007 09:22 PM
All times are GMT -7. The time now is 05:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
