Originally posted by ccd333 Exactly. And it is stated the K-r has a "decent live view auto focus" in the pros section, even though in the analysis earlier it was conceded that it is the best of the bunch in this area. Comparing its live view auto focus vs. the auto focus with phase detection and the viewfinder, you might call it decent.......but comparing it to everyone else it shines and therefore a better way to describe it in the pros section would be "class leading" (a phrase they use a lot for the K-x review).
The word decent was also used to describe how the K-r does with higher sensitivities. But in this case it gets a big boost....a "very" decent job.
I don't actually think the reviewer thinks of decent as the relatively positive, just above neutral term it typically is used in descriptions.....I think he's using decent here in a quite positive way. It would be interesting if that terms was used to describe features in other cameras he has reviewed. Might be worth a look.
Okay, here's a comparison of a review (specifically the pros section at the end) done by the same reviewer (Lars Rehm....I'm picking on you, Lars) for a camera that received a total score a few percentage points higher.....The Sony a850:
Class-leading resolution (as long as your lenses are good enough)
Very solid build quality, environmental sealing
Intuitive operation and uncluttered control and menu system
Excellent out of camera JPEG results with superb tonality, dynamic range, color
Excellent raw dynamic range gives lots of headroom
Almost 100% reliable metering and exposure
In-body image stabilization that works well (around 2 stop advantage)
Superb screen and attractive menu system
Excellent 'Quick Navi' control system
Large and bright optical viewfinder
Excellent handling and ergonomics
Excellent battery life and percentage battery status display
Value for money
I see a LOT of "excellents" and "superbs". Certainly the K-r compares to this camera on some levels (yes I know it's a full frame). Same reviewer, different cameras. At least it shows the reviewer is capable of using these kinds of terms. I've been hammering on the review, but not wanting to do it gratuitously.....I'm just trying to get a sense of how and why they review things the way they do. The reason I brought up the comparison with the a850 is not because there isn't a tangible difference between the two cameras.....it's to be expected. One is pro model and one is entry level. Apples to oranges, I get it.
The final scoring indicates not that big of a difference.....yet the terminology used to describe is not taking the classifications of the cameras into account. So....is superb just superb period? Or is superb superb for just the pro models? Or in this case just for Sony? Or should we just take good and decent as the equivalent to superb and excellent since it is on a relative scale with the entry level model?
