Originally posted by rrwilliams64 looking for an inexpensive alternative to the AF360FGZ
considering the Digital Concepts 918AF
thoughts, or anyone w/ experience w/ this flash? thnx
I don't own or have experience with that unit you cite, however on reading its specs I noted the absence of a Slave Mode (reqd for wireless use), and would suggest you seriously consider that in any external flash because it can be a useful additional feature to have for K-x/r (neither have a port for wired flash).
Also Slave is available std. in some brands~models for a similar cost; eg. You could get 2 of these [below] for less than the USD88.98 outlay for the 918AF you cite, and in my experience manual only operation is not a great burden in a cheap external flash. On the contary, it can be a bonus because TTL is less than useless, and sub-std PTTL of the cheapies doesn't really work well (if at all) on Pentax platform.
http://www.dealextreme.com/p/yongnuo-yn460-speedlite-flash-with-stands-soft-...00k-4-aa-32981
Honestly, this is TANSTAAFL territory. So either be prepared to pay for only the best top models, or accept the higher learning curve of manual-settings operation and generally less light output (per unit) of the inexpensive route.
Both can potentially achieve the same end results so little to worry about there.
.R. -- 'Semi-automation' is like 'getting half pregnant'.
