03-18-2011, 06:15 PM   #1
Used Pentax-A 50mm f2 lens and strange K-r behaviour
I just purchased the lens shown in the title from e-bay. When I mount the lens on my K-r, it causes erratic behaviour. Everytime I touch a button, the shutter clicks half-way. In Av mode the e-wheel erratically sets the aperture (lens set to A.) After taking a picture, every button (Menu, wheel, etc.) cause the shutter to click.
Any suggestions of what is at fault?
Thanks.
Gerry
03-18-2011, 07:28 PM   #2
Hypocorism's Avatar
QuoteOriginally posted by gstool Quote
General maintenance:
• Clean the mounting face and electrical ball-contact of the lens, and the camera mount too.
• Manually operate the aperture lever on the lens to make sure it moves smoothly, and, that it isn't bent.
• Twist the Aperture ring off, and then back onto, the A position a few times to make sure it seats at A properly (my 50/A doesn't seem very positive or give proper feedback [by that I mean feel, such as some positive click-in position] that its there).
• Set Menu C, tab 4, item 22, to 2.
Remount, and good luck.
.R.
03-19-2011, 07:25 AM   #3
Thanks a million for your quick reply. You were spot-on. the aperture control pin was bent inward toward the lens center. I cleaned the contacts for good measure and the lens works great now.
Is the permission to use the aperture ring necessary when the aperture setting is locked to "A"? My intuition didn't agree with that.
Thanks again.
Gerry
03-19-2011, 09:01 AM   #4
Hypocorism's Avatar
No, it's not. Your intuition is absolutely correct.
I only recommend leaving it on Permit because there is usually little reason not to, insofar as occasions will arise when you will prefer to manually set the aperture (by the physical ring).
In such cases it can be a great spoiler to have the shot all set up, only to lose it because the shutter wouldn't ... %^#$@&!
I'm sure you know the feeling.
.R.
50mm f2 lens, behaviour, button, camera, k-r, kr, lens, pentax k-r, pentax-a 50mm f2, shutter
DA* 50-135 very strange behaviour (?): help! lol101 Pentax SLR Lens Discussion 32 02-18-2018 05:26 AM
Tamron SP 19AH 70-210mm Strange behaviour aliasant Pentax SLR Lens Discussion 13 01-26-2011 03:11 AM
Strange focusing behaviour on K100D firefly Pentax DSLR Discussion 7 10-23-2008 07:15 AM
Strange Behaviour Tom Lusk Post Your Photos! 7 09-16-2007 05:10 PM
Strange results using non-pentax lens Dave54 Pentax DSLR Discussion 4 06-21-2007 04:48 PM
All times are GMT -7. The time now is 02:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
