03-19-2011, 07:56 PM   #1
K-r Shutter... vibration?
I saw one other post about this, but it didn't seem conclusive.
When I press the shutter, the shutter clicks as normal. But when the shutter closes, I hear this metal-vibration sort of sound.
Is this normal?
03-19-2011, 09:42 PM   #2
hcc
hcc's Avatar
It could be the SR. When you half-press the shutter button, the SR will take 1-2 s to stabilise the sensor (shake reduction) before the SR symbol (Green hand) appears in the viewfinder.
The SR mihgt be the noise that you hear, but it is usually not a metallic sound. (I do not have a K-r but K7, with no metallic sound.)
Hope that the comment will help....
03-19-2011, 09:48 PM   #3
Hmm it's not the SR (i think, i turned it off and tried again) because you hear the sound after you fully push down the shutter button. You hear it after the shutter goes down or the mirror flips back into place.
I'm hoping it's not the mirror...
Sort of sounds like when you hit a metal railing with your hands. You hear the vibration. Obviously it's not that loud though...
03-19-2011, 11:59 PM   #4
ovim's Avatar
If I put my ear close to the camera I can hear that sound but I really have to listen closely in a quiet environment. So I'd say it's normal unless the sound you're hearing is louder.
03-20-2011, 12:33 AM   #5
try use another lens if you have..
03-20-2011, 12:45 AM   #6
unfortunately i don't have another lens =X though it doesnt sound like it's coming from the lens
well at least everything is working fine. if it dies im hoping it dies within 1 year so i can use warranty xD
03-20-2011, 01:16 AM   #7
check if the autofocus switch is all the way down
to autofocus
03-20-2011, 01:38 AM   #8
yep the AF switch is down
03-20-2011, 05:47 AM   #9
okay when I took off the lens and shot it like that, the sound is basically gone. well it's hardly noticeable.
so that means it's something to do with the lens?
03-21-2011, 09:03 PM   #10
yes, the sound comes from the lens..probably from the aperture spring..that is why i asked you to try another lens..
also try that lens to another body..
i have this problem with my k200d before..different lenses will produce different degrees of sound..it is not lens only problem or body only problem..it is the combo problem..
i think the sound is only noticeable with the combo of your both body + lens..
camera, k-r, kr, pentax k-r, shutter
Mirror vibration/Leaf shutter Lunaray Pentax Medium Format 10 06-02-2010 12:00 PM
Full Frame 16-35mm f4 Vibration Reduction Nikon $1,259 Samsungian Non-Pentax Cameras: Canon, Nikon, etc. 23 02-10-2010 01:00 AM
Less vibration with quieter shutter? gfmucci Pentax DSLR Discussion 0 07-30-2009 12:06 PM
Lens vibration dampening tips? OrenMc Photographic Technique 9 06-29-2009 02:13 AM
Impact of vibration on K10D 2wheels Pentax DSLR Discussion 15 01-13-2008 07:23 AM
All times are GMT -7. The time now is 05:54 AM. | See also: NikonForums.com, part of our network of photo forums!
