03-19-2011, 08:44 PM   #1
Weird hapenings with my Kr
I have had my Kr since late Dec 2010
In the last week or so when I take a photo the shuter speed is very slow
at ALL settings even at the sports setting where to take 6 shots it could take 20 seconds or more
any ideas
03-19-2011, 09:38 PM   #2
hcc
hcc's Avatar
QuoteOriginally posted by costas60 Quote
any ideas
Can you be more specific? There might be two different issues:
* Do you mean that the shutter speed is always very slow (1" or slower) ?
If so, set the camera to the Green mode. (Dial mode = Green.) If you have still a very slow shutter speed even in Green mode, there is a pb with the camera. Send it to Pentax for warrenty repair.
* Is your camera slow to write your shot on the card? That is, you need to to wait 2-6 s before you can take another shot.
If this is the case, there are 2 likely causes:
(a) Your SD card is faulty. You may try another card first. Then try to reformat your card. If the pb persists, then change the card.
(b) You set (possibly by default) a lot of in-camera PP: eg, lens distortion correction, high-ISO correction ... The in-camera Post-Processing (PP) may take several seconds. I suggest to switch off all in-camera PP. Most Pentaxians would recommend you 'kill off' any in-camera PP, and to PP your shots on the computer.
I hope that the comments will assist you to resolve your problem.
03-20-2011, 01:11 AM   #3
QuoteOriginally posted by hcc Quote
thanks for reply
taking a picture the shutter clicks once then stops for a few seconds for sewcond click to finish taking the photo
I have reset back to factory settings
has been OK today
could there be a setting i did ??
will see if it slows down again
03-20-2011, 01:59 AM   #4
Hi Costas!
Do you have another memory card to try?
03-20-2011, 03:38 AM   #5
QuoteOriginally posted by Philippos Quote
Hi Costas!
will try that as well
I use sandisc ultra II
class 4
should I go to class 6 or class 10??
anyone knows if below card is any good
Patriot 8GB SD Class10 LX series signiture
http://www.patriotmem.com/products/detailp.jsp?prodline=4&catid=70&prodgroupid=66&id=902&type=6
http://www.patriotmem.com/products/groupdetailp.jsp?prodgroupid=66&prodline=...0SDHC&catid=70
03-20-2011, 05:23 AM   #6
ovim's Avatar
Did you by any chance have the drive mode set to 2sec delay?
camera, k-r, kr, pentax k-r
Weird tripod? harryi Pentax Camera and Field Accessories 5 03-04-2011 01:12 AM
Landscape That Weird Chill rustynail925 Post Your Photos! 4 10-15-2010 09:00 AM
Just weird graphicgr8s General Talk 11 07-07-2010 01:45 PM
Weird flare... pbo Pentax SLR Lens Discussion 2 09-02-2009 09:44 PM
Weird but i like it. knumbnutz Post Your Photos! 6 07-12-2009 03:40 PM
All times are GMT -7. The time now is 09:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
