Originally posted by huh Thanks for the reply. The lens on the T2i was Canon EF-S 18-135mm f/3.5-5.6 IS. The focal length was set to 69mm.
I checked the resolution test for both lenses on photozone.de. The DA70mm's center MTF50 at F8.0 is 2107, compared to 2436 of the other lens. Do you think the blur is caused by my shaky hands or just normal resolution for DA70 at the distance?
I wouldn't think it be the DA70.....it's considered to have consistent resolution regardless of aperture setting.
The interesting thing to me is the Canon had the IS lens.....but are you certain you had your in-body SR on with your K-r? If not, then yes...it is more likely to be your shaky hands. If so, it might
still be your shaky hands.
The other factor to consider is the extra megapixels on the T2i for a crop situation (over 50% higher resolution potential resolution.....so almost apples to oranges for cropping) If you look at the other items beside the numbers (the door for example) the blur is less pronounced on the K-r. Is there a way you can post the two door/address shots at full size with full EXIF?
The bikes don't show a big sharpness/blur difference as much as a contrast/color one. JPEG processing (or could one be RAW?) and various settings on the camera (all default?) could make a difference there. Like the default vs. natural for example......or contrast settings.
