I am a newbie looking to acquire my first dslr. I have now settled on the k-r and have found the following offer from ebay for $850:
1) Pentax K-r Body
2) Pentax Da L 18-55mm Lens
3)PENTAX DA 50-200mm f/4.0-5.6 ED DA-L Lens - Designed for exclusive use with Pentax KAF-mount digital SLR cameras including the *ist D and the *ist DS digital SLRs, the Pentax DA L 50-200mm f4-5.6 ED lens offers 4x zoom coverage in the telephoto range. Further, the lens features an angle of view from 31.5 degrees to 8.1 degrees (equivalent in focal length from 76.5mm to 306mm in the 35mm format).
The lens also incorporates an Extra-low Dispersion (ED) glass lens element (11-element/10-group optical construction) and two aspherical lens elements for true-to-life image reproduction and overall size reduction. The image circle in DA-series lenses is designed to perfectly match the 23.5mm x 15.7mm size of the CCD used in Pentax digital SLRs to optimize camera performance. The new design also contributes to a drastic reduction in size, weight and production cost, compared to 35mm-format counterparts with similar specifications.
Technical Details : 50-200mm DA-L Telephoto Zoom Lens with f/4-5.6 maximum aperture for Pentax DSLR cameras Incorporates extra-low-dispersion (ED) glass lens element and 2 aspherical lens elements Responsive Quick-Shift Focus System allows instant shifts from auto to manual focus Includes lens hood to minimize flare and ghost images; 4x zoom coverage in telephoto range Measures 2.6 inches in diameter and 3.1 inches long; weighs 9.2 ounces
4)Wide Angle Lens
This is a hi-definition black digital wide angle lens with macro. This lens features 0.45x professional high speed auto focus. This lens comes with a 10 year warranty.
5)Telephoto Lens
This 2x professional telephoto conversion lens has been designed to meet the highest optical standards for it's type in the photo industry. It has been crafted to work with ANY digital, still and video cameras. You just screw this lens on front of your existing lens or adapter. Optimized for use in digital equipment. Among the many makes whose products it fits are Sony, JVC, Olympus, Canon, Nikon and others.
6)16GB SD Memory Card + Multi Card Reader
7)Full Size Tripod + Table Top Tripod
8)Filter Kit 58mm
9)Soft Case for SLR cameras
10)Lens Cleaning Kit + LCD Screen Protector
Is this too good? Or are the lens really cheapie and bad? Should i just get the 18-55 and 50-200 and not bother with the rest of the stuff? Please help. Its so confusing with the hundreds of choices!
