04-21-2011, 11:48 AM   #1
[langtitle=mt]problems when recording a movie[/langtitle]
is it normal that when recording a movie with a pentax K-r the movie becomes noisy(grainy)? what are the best settingsto obtain the best result for a recorded movie?
04-21-2011, 02:01 PM   #2
HEEGZ's Avatar
Do you have movie quality set to the highest setting, or is it set lower? For example:
1280 x 720 pixels (720p)
vs.
640x480
Also, what lens are you using?
04-22-2011, 02:14 AM   #3
yes it is set to the highest resolution (1280 * 720) and the quality is set to best (3 stars)
i am using the 18-55 mm lens
04-22-2011, 02:15 AM   #4
ithe resolution is set to 12808 720 and the quality is set to best (3 stars)
04-22-2011, 07:07 AM   #5
HEEGZ's Avatar
Can you upload a movie to YouTube so we can see the problem you have?
04-22-2011, 09:08 AM   #6
you can check the video from the above listed link its uploaded on youtube. thanks
04-22-2011, 09:10 AM   #7
when you resize the movie to fullscreen and set the resolution to 720p you can see the noise
04-22-2011, 10:03 AM   #8
HEEGZ's Avatar
I am guessing that this is because of the low light in your house. I think if you have better lighting there will be less noise. The YouTube video looks normal to me, I don't think the problem is your camera, it is possibly the light.
04-22-2011, 10:08 AM   #9
in fact on youtube it seems to be less noisy than it originally is. i also tried to film in a theatre and still had the same problem :S
04-22-2011, 12:33 PM   #10
HEEGZ's Avatar
Indoors will usually have worse light and image quality than outdoors. You might check to see if you have the same problem outside. Or you could try using a different lens if you have one.
Perhaps someone else can comment with suggestions for specific settings when filming movies.
04-24-2011, 02:28 AM   #11
i tried using different lenses but had the same problem. when filming during daylight the movie quality is perfect. the problem is when filming in the evening
04-24-2011, 03:01 PM   #12
HEEGZ's Avatar
QuoteOriginally posted by alexia Quote
In my opinion this is as good as the quality will get and your camera is functioning correctly. Maybe a dedicated movie device will do better in low light, or perhaps a better lens will help. Personally I didn't find the image quality to be bad or distracting in your video above. People are used to seeing this now that YouTube and online video has become mainstream. Higher quality in low light will probably require a higher quality video camera. I only take images so I don't think I can be of any further help. Good luck!
04-24-2011, 03:45 PM   #13
hcarvalhoalves's Avatar
You need better light. At low light conditions, you will see the noise inherent from the sensor.
camera, k-r, kr, movie, pentax k-r
problems with compativility alejandro.garces Pentax DSLR Discussion 2 10-06-2010 01:15 PM
Optio W90 purple stripes in movie clips uuderzo Pentax Compact Cameras 7 08-03-2010 12:37 AM
K-7 Movie stops recording at about 50 seconds tsarbomba Pentax DSLR Discussion 13 03-01-2010 08:31 PM
recording movie on k7 deltchevi Pentax DSLR Discussion 5 12-19-2009 03:40 PM
How important is HD Movie recording to you? petercrane Pentax DSLR Discussion 12 07-18-2009 07:41 PM
All times are GMT -7. The time now is 05:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
