04-22-2011, 03:19 PM   #1
kooks's Avatar
Astrophotography with Kr???
Hi there..
I have been trying to hook up my Kr with my reflector telescope but i cant figure out how to do it.. i mean.. i beleave i have all the pieces that i need..
I have the T2 ring that gets to the camera boddy.. i have the other piece that connects that ring with the tube that gets into the telescope eyepiece.. so ..
But when i turn the camera on ( manual focus ) the only thing that i see on the screen or viewfinder is a blank screen.. like if the light is coming in but cant correctly process it..
Just to illustrate i have something like this:
OFCOURSE... PENTAX
I did some research and i found that some cameras ( didnt specified if Pentax ) have some system that doesnt allow to take pictures if the camera doenst detect a lens, but it can be desable, so the camera can take pictures and focus.. so This applies to Pentax?? if so.. where is that setting on Kr ??
Im i missing something??
04-22-2011, 03:28 PM   #2
Emacs's Avatar
Yes, there's a setting about "manual aperture" or something, in the last group of settings.
04-22-2011, 03:43 PM   #3
kooks's Avatar
mm if i go to the last group it says
"Using Aperture Ring" .. i switch it to Permited
Do u mean that setting??
04-22-2011, 03:57 PM   #4
kooks's Avatar
Nevermind.. i think that i finally got it.. =P
im going to try it at might and lets see how it goes...
04-22-2011, 04:06 PM   #5
For manual lenses, yes - you must enable the aperture ring. However, on the top of the camera there is a mode selector, that you can turn it to "Manual" (or M) or for longer durations (over 30 sec), B for Bulb, This way you can manually control the shutter time to whatever - 2 hours and 12 minutes, etc. The Kx was limited to an IR external shutter release. I do not know if the KR permits a wired or IR (or both) external shutter release. I looked in the manual and the Kr is IR only (page 323 and 147). You should probably turn SR off, since you are on a tripod...
http://www.pentaximaging.com/images/temp/63425760400466362725879manual_k-r_en_official.pdf
edit - You might want to set your shutter release for first push open, and the next push close the shutter. I believe you can also select 2 second mirror up, too.
04-23-2011, 07:12 AM   #6
Also get yourself an infared remote, cheap as chips on ebay and works a treat - probably best to avoid touching the camera if at all possible whilst shooting.
camera, cant, k-r, kr, pentax, pentax k-r, pictures, telescope
Astrophotography iClick Pentax DSLR Discussion 1132 05-25-2018 04:23 PM
Astrophotography with Film ajuett Pentax Film SLR Discussion 18 05-20-2012 11:11 AM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
All times are GMT -7. The time now is 06:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
