05-02-2011, 02:22 AM   #1
sany's Avatar
Tamron Adaptall 2 lens with K-r
Please educated me on the following (being a new comer to DSLR and Pentax):
1. How to use an adaptall lens? Do I need to get a adapter mount for my K-r?
2. Does tamron Adaptall and Adaptall 2 lenses required different adapters?
3. What will the shortcomings be in my K-r when used: Will there be Av, Tv or P modes available for the camera? Any metering issues?
4. Any other comments and advices on this?
thanks
05-02-2011, 04:33 AM   #2
aurele's Avatar
QuoteOriginally posted by sany Quote
you need an adaptal / K mount. Then you can use any adaptall lense.
Av : yes
Tv and Sv : no, except if your adaptall can handle "A" settings (i don't know if adaptall can do this, that's why i answered that.)
Yes, adaptall / K mount can be a bit expensive, but after that, you can found a lot of great lenses like 28mm f2.5 sell very cheap because it need the adaptall mount. So if you get an adaptall mount for cheap it's all good !
05-02-2011, 05:08 AM   #3
QuoteOriginally posted by aurele Quote
it can handle it if you can find an original A adapter...they can get quite rare and expensive, and some of them are sold but won't work so what you get is a M one.
What a great concept..and a shame it dissapeared...when i see adaptall i'm always hoping that someone who only makes manual focus lenses will pick it up again...
05-04-2011, 03:02 AM   #4
sany's Avatar
QuoteOriginally posted by Coeurdechene Quote
Thanks for that Coeurdechene and for your comments here. So when you say original A adapter you mean PK/A adapter mentioned in the above link. And I gather from your suggestion, if I buy PK/A adapter I will be able to use Av and Tv modes along with Manual. Am I correct?
I am asking this so I can go around and hunt for one....
I am also confused how to search for a proper adapter, should I call it adaptall to K mount or PK/A adapter for pentax?
Last but not least, will this adapter work in both adaptall2 and adaptall 1 lenses?
05-04-2011, 03:48 AM   #5
you are correct
you can search "adaptall PK/A"...
I think that it'll work with all of them ..i have a generic adapter that works as a K one and it's suitable for both lines.
If you haven't seen it yet adaptall-2.org this is a good page that can give you info about the adaptall lenses.
05-04-2011, 10:40 AM   #6
sany's Avatar
Thank You, is this one here a PK/A mount?
They don't show any contacts on the back that will send aperture info to the body also this one looks different from this one here which I guess is a PK adapter and not the PK/A.
For me that adaptall2.org site has no info on the mount details but there are info on the lens so not sure how it looks
05-04-2011, 11:23 AM   #7
No, that's a PK/M mount. A PK/A Adaptall-2 mount will cost between $80.00 to $120.00 (or more) depending on your luck in bidding on eBay. A PK/A mount will give you the same functionality as any Pentax A series lens; auto everything except auto focus. Here's a picture of the PK/A mount:
Hope this helps,
05-04-2011, 12:46 PM   #8
Try to get a Pk/A at a reasonable price...if you can't the PkM is fine too (M mode or Av wide open...and when in Av you can change the aperture ring and use the over/under expose option to compensate).
Not having Tv,Av,Sv is not a big loss.
05-09-2011, 02:26 AM   #9
sany's Avatar
Hi
thanks for that knowledge sharing!
Just some last couple questions from me:
1. do i need to worry about any dust issues getting thru the adapter or will it be same as any usage with a normal pentax lens? Maybe I am thinking too much!
2. Are there any issues with attaching and removing of adapters like I hear about ricoh pin getting stuck and all...
thanks again
one more here: when buying an adaptall lens do I have to buy the one specific for pentax (like sigma and others these days) or any adaptall lens and then the PK adapter takes care of it? this will help me fish for it elsewhere as well as I don't see much being traded in the marketplace.
05-09-2011, 05:34 AM   #10
Any adaptall will fit your K mount adapter...my nikon adapter is kind of tricky to put on the lens, the generic K adaptall adapter is simple...the original, i'm not sure if it will be a bit tricky as the nikon one or if it will be really easy as the generic K.
You shouldn't have any kind of issues if the adapter is a pentax adapter (they do sell Ricoh adapters with the ricoh pin...just don't buy a ricoh adapter and you're good to go).
I've had no particular trouble with dust...to be sure just use a rocket blower now and then to clean the parts and all will be fine.
05-09-2011, 11:15 AM   #11
sany's Avatar
thanks once again, let me now start the hunt!
adaptall, adaptall 2 lens, camera, k-r, kr, lens, pentax k-r, tamron, tamron adaptall
Tamron SP 35-80mm f/2.8-3.8 adaptall-2 01A -- very cute mf lens hinman Pentax SLR Lens Discussion 12 03-15-2016 01:41 AM
Tamron Adaptall & Adaptall 2 Mount: What's The Difference? minahasa Pentax SLR Lens Discussion 5 04-20-2011 07:26 AM
For Sale - Sold: Tamron 28mm f/2.5 Adaptall with Tamron Adaptall PKA mount jjdgti Sold Items 9 12-30-2010 10:00 PM
Tamron 17mm f/3.5 Adaptall Lens rodneya Pentax SLR Lens Discussion 4 12-05-2009 08:47 PM
Tamron Adaptall 90mm F2.5 Macro Lens Testing frank Pentax SLR Lens Discussion 6 07-13-2009 07:16 PM
All times are GMT -7. The time now is 09:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
