05-12-2011, 01:02 PM   #16
okay thank you .. that will be easy enough to remember .. using my own metaphors with it .. a lot of work I plan to do is landscape.. far and close up.. and cars .. both in motion and stationary
05-19-2011, 11:45 PM   #17
Ha, I thought I knew lenses until I got my K-r. It's confusing at first, but you get over it.
If you are comfortable shooting manual, or at least manual aperture, there are just so many lenses out there to try. If I had the bucks to spend I'd go for some of the nice * ones. You could also go the adapter and 6X7 route. Big heavy old glass
05-21-2011, 08:14 PM   #18
haha i dont think i want all of that. what is a good wide angle lens available as a k mount?
05-25-2011, 10:03 AM   #19
Old adaptal 2 lens can be found cheap to play with. An example might be a Tamron SP 28-80. Works in Av with a PK adaptal mount. 28 isn't that "wide" but I just can't seem to part with my old lenses (friends)
You can buy several "play" lenses for the cost of "fair" AF zoom.
A P/KA mount will cost more than it's probably worth.
05-25-2011, 02:07 PM   #20
To add to the slew of info, if buying older lens watch out for R-K mounts or any Ricoh lens. These lens will fit and work just like a K-mount, but some (not all) have a pin that can cause the lens to lock on the camera. If you get one of these lens you can easily remove the pin to use on a Pentax camera.
camera, k-r, kr, pentax k-r, questions
just a few technical questions about how manual lenses work wehavenowaves! Pentax SLR Lens Discussion 11 03-23-2011 09:19 AM
questions re WR lenses kpp80202 Troubleshooting and Beginner Help 4 02-08-2010 03:04 PM
More questions about macro lenses. chinotenshi Pentax SLR Lens Discussion 9 11-24-2009 08:51 PM
Have questions about 6x7 lenses MightyMike Pentax Medium Format 14 06-21-2009 09:44 PM
Some specific questions about two lenses Richie1978 Pentax SLR Lens Discussion 6 05-21-2009 09:01 AM
All times are GMT -7. The time now is 10:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
