playing with astrophotography is great fun, and easy enough for wide field stuff
here is my first try from a long while back with my K200D using Deep Sky Stacker. Taken with the kit DA 18-55mm AL II at 18mm and f4.0, ISO 1600 (thats the max on the old K200D). I took 8 15 sec exposures, add +2 EV in Lightroom then stacked those images using Deep Sky Stacker. This was out in the Great Dividing Range where you can see the Milky Way with your naked eyes. I'd love to go somewhere with a better view of the sky (this was just from the camp site, playing around you know) with a newer body (if i had one) with higher ISO.
Here is a single bulb exposure from a spot close to the previous image, but not up in the hills. Again the milky way was visible with the naked eye. This was same body, same lens, same f4.0, same ISO but a single 124sec exposure (was aiming for 2 mins) with long exposure NR turned on. I was trying to balance the exposure length while trying to keep the trailing of the stars to a minimum for this one.
Finally a simple star trail from the same evening as the previous shot. This was again 18mm and f4.0 but instead I used ISO 200 and a 372 sec exposure with long exposure NR turned on to get the trails. I happened to be quite fortunate that the wind was quite low and the tree wasnt moving. Think I may have light painted the tree a little with a torch actually...
As I said, simple stuff to try out, and good fun, especially if you are out away from city lights camping or some such. Have fun with your crazy high ISO bodies you lucky K-r owners!
