Originally posted by Eriol Yes, you have a point. But I must say, after approx. 4000 shots with my K-r I had a lot of situations where the front focus issue under any kind of artificial light was quite present. On the other hand, I remember only 2 (two) situations where the build in AF assist light was on. (Yes, yes: it is turned on in the settings menu ...).
So: When we were clamoring for such an AF assist beam, we actually meant that it should also go on from time to time.
For the AF light to work you always have to remove any lens hood mounted (reversely) on the camera - they might create a shadow ...
Before anything else, I'm not downplaying the problem, nor mean to be sarcastic
I actually suggested that (turning on AF beam earlier) as a fix in one of the threads here. I also mentioned why this FF firmware fix may never be released:
- That would render the additional AF hardware in the K-5/K-7 redundant. No one one want to pay for that. Marketing/sales will never allow it.
- It's not possible in the first place, hence the AF hardware
Like I mentioned about the lens hood, it didn't do that on my DS. I doubt it did on the K-x either.
There may be occasions you may want to use the pop flash in daylight, where you also want the lens hood on (to fulfill what it's designed for).
But still, that doesn't explain why they broke this combination in the K-r, and this definitely won't be fixed by firmware
