Originally posted by David T
I have been shooting well over forty years and have had the K100D, K10D, K20D, K-r, and K-5. I bring this up not to toot my horn, but to respond to those of you who are having flash issues and want to blame the camera. No offense intended, but I can't imagine why anyone with any experience would want to use external flash in auto or P mode. After reading this string, I tested my newer Promaster 7500 external flash on my K-r and K-5 based on what you were saying. Auto did better on the K-5 but the Priority mode was the same (similar to what you were describing). I always use external flash in manual mode, TV mode, or flash X-sync speed (K-5) mode (not often in this mode). I have absolutely no problems in either camera using these modes and get pretty much the same results using the same settings. I hope this helps.
I was expecting someone with your response. Getting the same or different results between K-5 and K-r when using manual, TV, flash X-sync speed is not the issue here. The original poster and I are complaining about the shutter speed the K-r chooses when in P mode and how it is different from every other Pentax DSLR model when in P mode.
I am very proficient in using my DSLRs in manual mode and I know how to adjust the combinations of aperture, shutter speed, ISO and external flash settings to get the results I want. Same is true with TV, AV modes etc.
I do a lot of interior real estate photography and switch to manual mode quite frequently for tricky lighting situations, i.e. bright windows with dark interior. Having said that, there are situations where P mode works real well.
If I'm in a situation where P mode isn't intelligent enough to get the photo correct then I have no problems switching to manual mode. If the P mode technology exists and does a good job of balancing ambient light with flash and is more efficient or quicker than fiddling with the camera to manually figure out what flash, aperture, and shutter speed combination works best then a real pro is not going to let snobbery prevent him from using P mode.
The majority of the interior photos displayed in this gallery were taken in P mode.
Seven Arrow Photography | REAL ESTATE GALLERIES
