06-26-2011, 10:15 PM   #1
ajaya's Avatar
how many shots can be taken with KR battery full charge ?
Hi all,
Yesterday i observe that for one full charge of KR battery i am getting 200shots only (10 to 12 with flash usage) i would like to know how much other KR Users are getting for one recharge?
AJ
06-26-2011, 11:19 PM   #2
ions's Avatar
Hi,
I can take up to 400 shots (but never less than 250).
Display of my K-r most of the time is turned off.
06-26-2011, 11:34 PM   #3
ajaya's Avatar
QuoteOriginally posted by ions Quote
Hi,
i dont use live live to take photos but still not able to understand why less backup does it depends on MF/AF type we use for taking photos ?
06-26-2011, 11:41 PM   #4
QuoteOriginally posted by ajaya Quote
Yes. AF.C is more power hungry - particulalry when set for priority on focus instead of speed when shooting continuous. AF would also be more power hungry than MF.
06-27-2011, 01:12 AM   #5
ajaya's Avatar
QuoteOriginally posted by Bill_R Quote
so that means 500+ shots only with MF not with AF
06-27-2011, 01:20 AM   #6
Your shot count on the Lithium battery seems low. I'd try another or get an adapter and try AA's (recommend Eneloops).
06-27-2011, 01:44 AM   #7
ions's Avatar
actualy i didn't meant Live View. i'm just turning display (all settings, photo preview, etc) off.
06-27-2011, 02:19 AM   #8
ajaya's Avatar
Oh in that case i think what i am getting is normal or any prob with camera !
06-27-2011, 02:57 AM   #9
My K-r comfortably gets about 400 per full charge too; on AF-S, no pop-up flash, no Live View either.
Whereas it's a bit more finicky with the AA-battery adapter coupled with some 3-year old eneloops, giving no more than 300 shots usually.
06-27-2011, 04:38 AM   #10
Philoslothical's Avatar
It's hard to say, as it depends a lot on the way you use the camera, how much time you spend reviewing pictures on it, and especially if you're using the flash. Shooting with flash seems to cut what I can take by about half, maybe more. As others mentioned, Live View will also drain it quick.
The best solution is to get another battery or two, keep them charged, and then you can swap them out in the field with little hassle. You might find that your original battery wasn't in good shape when you compare it to new ones, and if so, you know the problem was with that.
06-27-2011, 04:59 AM   #11
mikerigel's Avatar
I've been shooting vacation resorts lately for websites and I always come home with between 600 to 800 shots, on the same battery charge.
I use external flash and auto focus only to setup the shot, then I switch to manual focus for consistency between shots.
I always have the AA adapter with me with some rechargeables just in case but so far, I only had to use them once, when I was over 900 shots.
06-27-2011, 05:04 AM   #12
ajaya's Avatar
how about getting a battery holder instead of spare battery? i found one in ebay but not sure how good it is?
Brand New Battery Holder Box for Pentax KR K-R Camera | eBay
or shall i go for pentax branded one?
NEW D-BH109 AA Battery Holder for the Pentax K-r CAMERA | eBay
06-27-2011, 06:13 AM   #13
A battery holder for AAs is fine, provided you get good quality rechargeable AAs to go with. The most popular here by a margin is the Sanyo Eneloops.
Shouldn't matter which battery holder you get. It's a pretty simple device.
06-27-2011, 08:20 PM   #14
ajaya's Avatar
QuoteOriginally posted by Philoslothical Quote
thanks lot for the tip i will get the sanyo battery soon.
06-28-2011, 06:23 PM   #15
GerryL's Avatar
Doesn't necessarily have to be Sanyo Eneloops.
As long as they are marked "Hybrid" or "Pre-charged", they should all be the same.
You can get them as Rayovac Hybrid, Kodak Pre-charged, and there are others I can't really recall.
I both have the Eneloops and the Rayovac.
battery, camera, charge, k-r, kr, kr battery, pentax k-r
A company asking me for a quote on full rights photo. how much to charge? CRPhoto Photographic Industry and Professionals 13 02-21-2013 02:55 AM
First battery charge. How long? napawino Pentax K-5 12 06-23-2011 05:00 AM
X90 battery doesn't hold charge jpzk Pentax Compact Cameras 6 05-10-2011 06:55 PM
How long to charge battery? schmik Pentax Camera and Field Accessories 20 05-19-2010 09:36 AM
Battery charge info in the image file dbh Pentax DSLR Discussion 6 03-06-2008 08:46 AM
All times are GMT -7. The time now is 03:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
