06-30-2011, 02:55 AM   #1
adwb's Avatar
locking the mode dial any tips?
Has anyone had any bright ideas over how to stiffen up or lock the mode dial on a K-r ?
On my k10 its stiff and does not alter and on the K5 its locked but I find on the KR it constantly gets moved getting it in and out of the bag which is a pain in the you know where
it's the second body and gets grabbed used and dropped back in the sling bag at weddings etc. and I am tired of constantly having to remember to check it.
I suppose it might pull off which would fix the problem
06-30-2011, 04:53 AM   #2
audiobomber's Avatar
I have no answer to offer, just some sympathy. The K-x has the same problem, the dial moves just by handling the camera. This has NEVER happened with my K20D, not even once. I found the lock on the K-5 annoying. They should have just used the same tension as on the K20D and scrapped the lock. At least a lock is better than a wandering dial.
06-30-2011, 05:14 AM   #3
Philoslothical's Avatar
I'm a bit surprised by this topic. Maybe it's just that my K-r is still quite new (2 weeks of use) but the dial on mine is stiff enough that it's a pain to change accurately if it's up to my eye.
Perhaps yours is just looser than others? Sorry I have nothing to suggest to fix it.
06-30-2011, 06:01 AM   #4
I remember this "problem" with my K-x. Didn't bother working out a solution though. Can you jam some kind of shim between the mode dial and the prism hump? A toothpick or a piece of paper or plastic as a makeshift lock?
Regards,
--Anders.
06-30-2011, 08:32 AM   #5
I tried this and it worked. Get a thin rubber band and stretch it out until it is thin enough to fit in between the housing and the dial. You may have to pull it back and forth and down to work it in. If it changes the setting, just pull it down and back until the setting goes back to what you want. Clip the excess rubber band off to make it neat. Carry spare rubber bands in your camera bag and you're set.
07-01-2011, 01:14 AM   #6
adwb's Avatar
QuoteOriginally posted by gp1806 Quote
HA, great minds think alike , that was my solution to try but I was wanting to see if ,like usual, I had missed the obvious.
bag, camera, k-r, kr, mode, pentax k-r
Help! Mode Dial stuck? chriiisty Troubleshooting and Beginner Help 6 03-14-2011 01:05 AM
k200d mode dial help!? MoeRoadKill Troubleshooting and Beginner Help 8 01-20-2011 05:20 PM
Dial mode not work JoZ3 Pentax K-r 3 12-26-2010 06:27 AM
Mode Dial Question pomegranate Troubleshooting and Beginner Help 3 12-04-2010 12:50 PM
Canon offers locking mode dial for 7D and 5DMkII... for $100 deadwolfbones Non-Pentax Cameras: Canon, Nikon, etc. 2 12-02-2010 11:46 PM
All times are GMT -7. The time now is 03:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
