06-30-2011, 09:06 AM   #1
expanded sensitivity ?
expanded iso sensititivity,
what is this for ?
and why is the lowest iso 200 without using the above feature ?
06-30-2011, 09:31 AM   #2
This setting boosts the ISO range to 100-25600 instead of 200-6400.
Pentax thinks that there is negligible gain outside of the standard ISO range, and it's conceivable that outside of the standard range, software does most of the work rather than the sensor.
07-01-2011, 01:07 AM   #3
so i take it that iso 100 does not provide better quality than iso 200 on the pentax k-r ?
07-01-2011, 01:17 AM   #4
adwb's Avatar
QuoteOriginally posted by mrfatpooh Quote
correct but itdoes allow you to use a slower shutter speed than iso 200 in any high bright situation or if you are trying for a slow shutter speed to say slow blurry wave or water effect in a image.
07-01-2011, 01:34 AM   #5
twitch's Avatar
If you check DXO you'll see iso80 has a greater dr than iso100 or iso200
07-01-2011, 03:25 AM   #6
QuoteOriginally posted by twitch Quote
what is dr ?
07-01-2011, 03:28 AM   #7
twitch's Avatar
dr = Dynamic range
07-01-2011, 03:30 AM   #8
and DXO what where is that ?
07-01-2011, 03:38 AM   #9
so are you saying the pentax k-r does iso 80 ?
I have expanded the sensitivity and can now see iso 100, but not 80 ?
07-01-2011, 03:41 AM   #10
twitch's Avatar
Sorry, K-5 does 80, K-r & K-x only go down to 100. But still, DR at 100 is better than 200. Google DXO.
07-01-2011, 03:43 AM   #11
thanks for the info Twitch
07-02-2011, 06:11 AM   #12
Might be correct if ISO 100 was a true ISO 100. Expanded sensitivity on the low end often (depending on how it is applied) overexposes by 1 fstop then truncates the highlights and leads to a reduction in Dynamic Range.
07-03-2011, 06:01 AM   #13
I have noticed slightly less noise (not that there's much at all on either) with ISO 100 than 200, so there is some benefit there.
07-03-2011, 07:52 AM   #14
ricoh.pentax's Avatar
QuoteOriginally posted by ccd333 Quote
when you print it at 4x6 inch.. none would notice the differences between 100 200 or 640 .. so, turn off the expansion, enable highlight correction youll get better result
camera, iso, k-r, kr, pentax k-r
Expanded Sensitivity rvannatta Pentax K-5 10 05-19-2011 02:27 AM
Expanded Sensitivity Range sany Pentax K-r 3 04-25-2011 12:06 AM
Why would you want Expanded Sensitivity off? Javaslinger Pentax K-5 8 01-19-2011 09:16 AM
Expanded ISO Sensitivity problems. noaslplease Pentax DSLR Discussion 2 12-26-2010 12:20 PM
K20D EXPANDED SENSITIVITY-ISO 6400 charliezap Pentax DSLR Discussion 2 02-06-2010 06:07 AM
All times are GMT -7. The time now is 03:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
