07-11-2011, 09:23 PM   #1
bwDraco's Avatar
Continuous shooting with shoe-mounted flash slower, but not in Live View
I've been playing with my PENTAX K-r and Metz mecablitz 50 AF-1 digital flash unit in continuous shooting mode, and I've noticed some odd behavior.
The flash is set to manual, 1/128 power. The camera is set to manual exposure mode with 1/180 shutter speed, continuous drive high, manual focus. When I use the optical viewfinder, the frame rate is lower than normal, at about 3.0-3.5 frames per second. However, when I do this in Live View, the camera fires away at full speed. In both cases, the flash fired on all shots.
Why would there be a speed discrepancy? Is this a firmware bug?
--DragonLord
07-11-2011, 09:34 PM   #2
I was going to suggest that it might be because the mirror stays flipped up when using LV.. but my K20D it seems cycles the mirror in burst even when using LV.. so unless there is a different behaviour, its not that.
Looking through the OVF, do you notice if the mirror flips every shutter cycle when using LV ? I imagine in AV or TAv etc it would still flip the mirror to do the exposure calcs, but no idea if in M mode and LV it just leaves it up....?
I'm just guessing...
07-11-2011, 09:42 PM   #3
bwDraco's Avatar
QuoteOriginally posted by adr1an Quote
Yes, the mirror is cycled on every shot in Live View.
--DragonLord
07-11-2011, 09:44 PM   #4
QuoteOriginally posted by DragonLord Quote
--DragonLord
Ah well - sorry - was a guess anyway as I said... Good Luck on finding the problem/solution !
07-11-2011, 10:17 PM   #5
Ash
Community Manager
Ash's Avatar
After asking Pentax support regarding the slower continuous frame rate, I was told that is was a camera limitation but they denied the slowing down while flash was off yet still mounted on the hotshoe (as occurs with my K-5).
07-12-2011, 09:57 AM   #6
bwDraco's Avatar
Thanks, but why would the camera fire at full speed in Live View with flash on each shot? Note that my camera did not slow down when a flash is off while on the hot shoe.
--DragonLord
camera, flash, k-r, kr, mode, pentax k-r, view
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
Will the metz 48 af1 mounted to camera hot shoe trigger af360 wirelessly? boosted03gti Flashes, Lighting, and Studio 11 10-26-2010 02:36 PM
Continuous shooting fekish Pentax DSLR Discussion 8 09-24-2010 05:58 AM
K-7 Continuous Shooting brosen Pentax DSLR Discussion 17 08-29-2010 06:24 PM
Beauty Dish for shoe mounted flashes? MidwestMax Flashes, Lighting, and Studio 11 10-11-2009 11:24 AM
All times are GMT -7. The time now is 02:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
