07-26-2011, 11:06 PM   #46
QuoteOriginally posted by mlatour Quote
Below are a few links to the website I participate in, examples of urban / street lighting
where my K-x (used for all of these pics) focuses fine while my K-r using the sames lenses
just doesn't work well at all under the lights. Same lenses but in natural light, the K-r is spot on.
(note my K-x AF was recently calibrated at Pentax using their shop's 'master lens' as a baseline)
CODE ROUGE - Intervention
Lenses used : Sigma 18-50mm f/2.8 EX DC MACRO & DA 12-24mm
Our website's main page: CODE ROUGE - Montreal firefighters unofficial website
for those interested in firefighting related infos and fire grounds photography in Montreal.
Anyway, I will be sending the K-r back to Pentax soon for inspection/repair...
Michel
Those are excellent shots. Was any post colour correction done? The light seems fairly cool so I'd definitely send the k-r in with the lens you usually use. Put it this way, there's nothing to lose by sending it in except some time.
07-27-2011, 02:57 AM   #47
I do very little post correction to my pics, a bit of 'sharpen' and 'clarify'
is usualy all that is done, but nothing much is ever done to the colours
unless they are really off.
The webmaster and I use the same older version of 'Paint Shop Pro 7' to PP.
For the website's intended audience, pic subject is the priority way before image quality.
Michel
07-29-2011, 03:03 AM   #48
From 1.10 to 1.11, monitor issue??
Just upgraded from 1.10 to 1.11 and soon after that (not during the first shots after the upgrade but the next day) I had this issue which I haven't faced before during my six months with K-r:
After shooting, the LCD monitor became black and white and was filled with horizontal stripes...The Instant Replay image was seen behind those stripes, but without any colors. Also the Menu looked like that after the Instant Replay view had disappeared.
I powered off the camera, then turned back on, display was OK but the same thing happened after the next shot.
Then I removed the battery for about 10 seconds (it was fully charged), and after that K-r did it's job as always, no problems any more.
The images were all OK in SDHC card, so luckily the LCD monitor was the only one malfunctioning.
So, I have no idea if that was caused by the new firmware or not.
Any others here with a similar problem after (or before) upgrading to 1.11?
07-29-2011, 06:38 AM   #49
I've never had that specific problem, but doing a hard reset (pulling the battery for at least 10 seconds) solves an amazing range of problems in all sorts of electronics gear, from printers to cell phones.
07-30-2011, 10:24 PM   #50
dorian_gray's Avatar
upgraded to 1.11 and never had a problem
08-10-2011, 03:59 AM   #51
SJR
Hey guys, got some problems with downloading... Have copy that FWCDC208B file to memory card, but when I put camera on (while pressing menu) there comes "Pentax Kr Ver: 1,00" text. So what I'll do to get 1.11?
08-10-2011, 04:04 AM   #52
Ash
Community Manager
Ash's Avatar
Put the firmware file in the root directory of the SD card then hold the menu button while you turn the camera on.
08-10-2011, 04:15 AM   #53
SJR
Thanks buddy!
08-10-2011, 09:33 AM   #54
lovejoy's Avatar
Firmware Ver 1.00
I Just checked my K-r is using version 1.00. I would like to get the latest 1.11 firmware so should I upgrade to Version 1.01 first and then the later releases to benefit from all the changes or just downloading the latest one would do?
Cheers
08-10-2011, 09:38 AM   #55
sany's Avatar
QuoteOriginally posted by lovejoy Quote
Cheers
You can go straight to 1.11 directly.
08-14-2011, 10:00 PM   #56
QuoteOriginally posted by Basten Quote
Hi,
I have a K-r running 1.01 and I had the same issue yesterday.
I don't think it's related to firmware 1.11.
Idan.
08-15-2011, 08:24 AM   #57
excellent!
08-18-2011, 07:35 PM   #58
knishita's Avatar
QuoteOriginally posted by IdanM Quote
Hi,
Idan.
Yep, I have K-r with 1.01 and have same issue once in a while for no obvious reason. I do not believe it is the firmware 1.11 issue.
01-17-2012, 02:23 PM   #59
which version to download
I've been lurking for a little while, reading some interesting stuff about using older lenses on the K-r (which I love, by the way). Inspired me to go out and buy a couple of lenses on eBay (waiting for them to come in) and to sign up for the forum. Now to the real reason for this post.
I went to the firmware download page to grab the latest firmware update for my K-rand saw versions for Windows and Mac. I use Linux. Where does that leave me? Which version should I download? It appears that the Windows version is a self-extracting file (presumably if you have Windows), so I'm not sure if I can use that one. The Mac file is apparently a .zip file, which I might be able to extract.
Are there other Linux users on here who can provide some guidance? Thanks.
01-17-2012, 03:08 PM   #60
The file just needs to be extracted and put on your sdcard. Grab the zip and open it with 7 zip and it should be fine.
camera, k-r, kr, pentax k-r
K100D ver 1.02 Firmware Update Frosty Pentax DSLR Discussion 6 04-29-2010 12:27 AM
Problem upgrading my K-x to firmware ver. 1.01 Tim_R Pentax DSLR Discussion 7 03-09-2010 05:26 AM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
For Sale - Sold: vivitar Seeries 1 70-210mm (ver. 3) jkglogau Sold Items 5 09-11-2009 09:34 AM
All times are GMT -7. The time now is 06:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
