I have been having some issues under tungsten light. I am using a focus card.
Using Pentax zooms 55-300 and 35-80. For each lens at the upper zoom the focus is spot on. But when I go down to the bottom end. The focus is patchy and has some ff or bf issues.
Will have to test outside, today, to see if there is the same problem in sunshine.
The focus card is A4 and probably useless in the low range because you cant get close enough to really be able to see the printing clearly. Manual focus, forget it.
Did some more tests outside and the issue is still a bit apparent, but acceptable. Probably just as difficult to focus manually, at the lower zoom levels, when the same distance form an object, using the upper zoom levels.
Reason: Further testing carried outside
