Originally posted by bros Is there a setting to let you know what depth of field you will get before shooting a photo?
DoF preview is available with the on/off collar - if you slide it past the "On" setting, it activates DoF preview which you can either see on the LCD, or via the viewfinder (depending on your menu settings - I believe the default is LCD.)
Originally posted by bros The other issue is that I cannont find how to change the iso setting to include 100 iso
You need to enable "extended ISO range" and disable highlight correction in the menu.
Originally posted by bros Finally, the camera is ste on 12meg picture quaility (which is what I want) however the photos taken have come out less than 6meg (5.8meg) why is this?
Because you are measuring two different things. Megapixel ("12meg") is the amount of data captured by the sensor, megabyte is the size of the file.
