Originally posted by deepblue Hello guys, I have an issue with a HOYA HMC ZOOM & MACRO 80-205 I bought at ebay thinking it would work on my Kr. The lens actually fitted but the same F_ _ appears. The above procedure simply doesn't work unfortunately.
If you set it to permitted then it is working as intended. The "F---" appears because the camera has no idea what the f stop is. A non "A lens" isn't capable of communicating this information so it just flashes "F---". However, unlike before, you should see a shutter speed now and you should be able to take photographs. Make sure you're also in M mode and using "green button" metering.
