09-10-2011, 06:03 PM   #1
Are my images over noisy
Here is a link to a cropped of a photo I took yesterday, do you think that there is more noise than you would expect at ISO400? My photos mostly look line when fitted to my screen but if I zoom in at 1:2 there is more noise than I would expect.
https://picasaweb.google.com/102266651534763504610/Random#5650900636034559282
Thanks
09-10-2011, 06:26 PM   #2
Would be nice if the full exif were intact (the forum automatically shows it if it's available; the picasa link is broken). Is this a 100% crop?
09-10-2011, 06:35 PM   #3
Sorry, trying to work out why the link isn't working.
Thanks
Edit: hopefully link should be working now. You can find the full exif data there and can see a 100% image. I think the one shown here is at around 90% anyway.
09-10-2011, 06:48 PM   #4
kiwi_jono's Avatar
If thats 100% crop then I don't see much in the way of noise - the focus appears to be more to the foreground of the image and there appears to be a bit of murkiness to the air in the background.
I think my K-x would look about the same.
09-10-2011, 07:06 PM   #5
Ok, maybe I'm just expecting too much. The images look fine at any size I'm likely to print at anyway, so it doesn't really matter. I just need to stop pixel peeping.
09-10-2011, 09:08 PM   #6
lammie200's Avatar
Hard to tell...
QuoteOriginally posted by Smilesy Quote
Like Adam said, it is hard to suggest anything without seeing the EXIF data.
However, I would think that this could have easily been shot at ISO 80 or 100 with the aperture opened up a bit more. There are definitely times when you would need to shoot at ISO 400 outdoors in daylight. However, those times usually involve capturing a fast moving object by increasing the shutter speed, or shooting totally within shadow with a slow lens. I am guessing that neither is applicable here.
Also, you can change the sharpness with a menu selection. That would help. You can also play with in camera ISO noise reduction. I usually turn that completely off though because I find that it slows the camera down and masks poor exposures. I feel like it is a better challenge to get the exposure right.
Don't give up. There is always room for improvement.
09-10-2011, 09:30 PM   #7
Wheatfield's Avatar
It's kinda underexposed. That'll make it noisier.
09-12-2011, 07:19 AM   #8
Thanks for the respones. Next time I'll try using a low ISO and see if that helps. Here is the exif data:
Date 10 Sep 2011 12:03:35
Camera PENTAX
Model PENTAX K-r
ISO 400
Exposure 1/13 sec
Aperture 11.0
Focal Length 18mm
Flash Used false
White Balance 0
Metering Mode 5
Exposure Programme 3
Exposure Bias 0.0
Date and Time (Original) 2011:09:10 19:03:35
Colour Space 255
X-Resolution 72.0
Y-Resolution 72.0
Resolution Unit 2
Exposure Mode 2
Focal Length (in 35 mm film) 27
Lens smc PENTAX-DA 16-45mm F4 ED AL
Lens ID 4 254
Lens Information 160/10 450/10 40/10 40/10
The sky in the image is pretty bright, hence the fore ground has underexposed. I think if I had bumped up the exposure much more it would have clipped a lot of the bright area in the sky.
camera, k-r, kr, noise, pentax k-r
Noisy KR - My old was K100D fazalabbas Pentax K-r 16 08-12-2011 04:29 PM
Macro Noisy Cicada eaglem Post Your Photos! 8 01-08-2011 01:46 AM
Noisy Images alowis Troubleshooting and Beginner Help 18 12-30-2010 04:04 AM
AF is noisy ruggiex Troubleshooting and Beginner Help 9 06-25-2010 04:43 PM
Noisy high iso images are useful alehel Pentax DSLR Discussion 17 04-07-2010 08:28 AM
All times are GMT -7. The time now is 10:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
