09-15-2011, 01:19 PM   #16
Thanks Digitalis I just wondered.
Mike
09-28-2011, 04:07 PM   #17
Would IR pictures of your house show where you needed more insulation?
IR pictures of your house would absolutely show you the areas where you have heat escaping from your building envelope... However all of the IR photography discussed here (whether it's using a filter in front of an unmodified camera, or a camera with the internal filter replaced with an IR pass) is more accurately described as NIR, or Near Infrared. This is the range of light just barely outside of the visible spectrum at the red end. I don't know where the sensitivity of the Pentax sensors starts to fall off, but the NIR range is from about 800-2500nm. Thermal imaging cameras use spectrum at the other end of the infrared range, starting at about 8000nm.
09-28-2011, 04:23 PM   #18
Digitalis's Avatar
QuoteOriginally posted by hubcapboy Quote
...more accurately described as NIR, or Near Infrared. This is the range of light just barely outside of the visible spectrum at the red end. I don't know where the sensitivity of the Pentax sensors starts to fall off, but the NIR range is from about 800-2500nm. Thermal imaging cameras use spectrum at the other end of the infrared range, starting at about 8000nm.
Correct, however Silicon based imaging sensors lose their sensitivity to Ir at frequencies beyond of 1000nm - to image even longer wavelengths you have to use specialised GaS* based imaging sensors.
*Gallium Arsenide
camera, filter, images, ir, k-r, kr, pentax k-r
Wood's Glass UV filter good buy! (but) newarts Ask B&H Photo! 1 02-13-2011 10:44 AM
help for a newbie...DAL lens hood and filter questions, not sure what to buy johnior Pentax SLR Lens Discussion 5 12-08-2010 11:18 PM
Should I buy a UV filter? yotam Troubleshooting and Beginner Help 23 09-14-2010 05:10 AM
Should I be a good Pentax choirboy and buy a DA 15 Limited or buy the Sigma 10-20mm? tokyoso Pentax SLR Lens Discussion 42 03-14-2010 04:54 PM
Where do you buy the ND 400 filter? raider Pentax Camera and Field Accessories 10 02-25-2009 01:07 PM
All times are GMT -7. The time now is 04:59 PM. | See also: NikonForums.com, part of our network of photo forums!
