View Poll Results: How much af microadjust for incandescent and tungsten ?
-1   00%
-2   00%
-3   00%
-4   00%
-5 222.22%
-6   00%
-7 111.11%
-8   00%
-9   00%
-10 666.67%
Voters: 9. You may not vote on this poll
10-15-2011, 10:55 PM   #1
Eruditass's Avatar
Incadescent and tungsten front focus: how much autofocus fine adjustment?
How much microadjust do you use for these lighting conditions without changing WB?
10-16-2011, 05:53 AM   #2
dragra's Avatar
Zero. If you do manual WB up first.
10-19-2011, 04:41 AM   #3
QuoteOriginally posted by Eruditass Quote
Hi,
I am an amateur photograph and I am not sure about the impact of my own capabilities on wrong focus. My personal feeling is that the FF is less relevant with the latest firmware, even though nothing was mentioned by Pentax in this regard. However, the FF is still present.
I do not fine adjust, neither do I change the WB. Especially with a wide aperture I tend to do at least two shots, where one of them focuses a bit "behind" the object. In other words, I play with the focus a bit. This usually brings up fine results.
Cheers,
Eriol
10-19-2011, 10:17 AM   #4
krebsy75's Avatar
This didn't work with the K-r when I had it. I was blown away with this realization.
QuoteOriginally posted by dragra Quote
10-19-2011, 10:55 AM   #5
Deimos's Avatar
Are you saying that if you manually WB there is no longer FF in Tungsten?
10-19-2011, 11:12 AM   #6
Eruditass's Avatar
QuoteOriginally posted by Eriol Quote
Cheers,
Eriol
It's a known problem that the AF sensor is affected by the light temperature and wavelength. That's why the K-5 has a color sensor. Focus-overriding is fine in some occasions, but not all.
10-20-2011, 07:43 AM   #7
QuoteOriginally posted by Deimos Quote
Weird thing I found recently is "tungsten" WB made no difference on my camera, but "shade" seemed to help.
10-20-2011, 09:46 AM   #8
dragra's Avatar
Exactly.
I Don't understand how a photographer's approach to artificial light can be different.
If you think as a photographer should you will be close to what Pentax was thinking.
camera, k-r, kr, pentax k-r
K-5 Manual Lens Front Focus & Focus Beep woes fixed kneonx Pentax K-5 14 04-12-2014 03:47 PM
AF Assist Lamp and Tungsten Focus Inaccuracy GrinMode Pentax DSLR Discussion 11 01-28-2011 09:45 PM
POLL: Who has front-focusing in tungsten lighting? soccerjoe5 Pentax DSLR Discussion 17 02-01-2010 05:06 AM
Proposed solution to Tungsten Front Focus laissezfaire Pentax DSLR Discussion 6 01-20-2010 10:59 AM
Front Focus and tungsten light question Big G Pentax DSLR Discussion 8 01-18-2010 12:25 PM
All times are GMT -7. The time now is 12:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
