Originally posted by jfca283 I don't know what does it make the green button.
It's a shame as a newbie to take pictures so awful with a good camera.
No, it isn't, I think that's rather normal.
The concept of the Green Button on Your K-R is rather easy to understand. If You're using an (old) manual lense other then a Pentax A-Lense or lenses with an A (automatic) position on the aperture ring You're camera does not know which aperture is being used, since there are no electronic contacts on Your lense to let the camera know. For this reason pressing the green button in manual mode (M on Your mode dial) stops down the aperture to it's actual value and calculates the correct metering (taking into account shutter speed and iso settings as well). It gives You back a correct metering which You can use. The problem is that when Your subject moves and You turn Your camera into the subjects directions the metering may well be wrong then because Your camera does not update the metering automatically for You. You'd have to press the green button as well. Why not start with more static pictures to get a feeling for it?
Ralf
