12-02-2011, 11:03 PM   #1
K-r and Tamron AF 28-75 f2.8 lens
I just received the Tamron AF 28-75mm f2.8 lens. It has an aperture ring. The settings go from A 32 - - - - 2.8. Does the aperture ring need to be set to A at all times or can you manually pick the aperture setting you want to use. I currently have aperture ring set to permitted under the custom menu settings. I mainly use M, AV or TV capture settings. Any suggestions or answers are appreciated.
Thanks,
Daniel
12-02-2011, 11:07 PM   #2
Docrwm's Avatar
You've done the first important thing - you set the menu to allow you to use the aperture ring. If the aperture ring is in the 'A' setting then the camera can control the aperture either automatically or at your direction via settings. If you put it on another setting you are manually setting the aperture on the lens. One of the advantages of the A lenses over the M lenses is the ability of the aperture to be controlled via the camera interface.
12-03-2011, 12:03 AM   #3
To manually change the aperture you should leave the ring in A and then use Av mode to specify the aperture via the camera. No harm in allowing use of the aperture ring, but then it's pretty much going to behave like a manual lens.
af, af 28-75 f2.8, aperture, camera, f2.8, k-r, kr, lens, pentax k-r, settings, tamron, tamron af
Tamron 17-50mm, Tamron 28-75mm, Sigma 17-70mm, which lens for my trip to Greece? macky112 Pentax SLR Lens Discussion 15 11-20-2011 03:08 PM
odd front focus problem with kit lens and Tamron 18 - 250mm lens jlaubza Pentax DSLR Discussion 12 10-30-2011 09:42 AM
lens comparison- fa50mm / tamron 17-50mm / tamron 28-75mm bimjo Pentax SLR Lens Discussion 11 03-16-2010 01:10 AM
Question about Tamron TAMRON AF 28-300MM F/3.5 - 6.3 XR DI LD ASPHERICAL LENS zone24russ Pentax SLR Lens Discussion 5 01-07-2009 11:18 PM
All times are GMT -7. The time now is 10:32 AM. | See also: NikonForums.com, part of our network of photo forums!
