Originally posted by Philoslothical Hmm, pretty sure no matrix metering with A lenses on the K-r, unsure of other models. I'll check this in a bit, but I'm fairly sure it's limited to spot and center weighted.
K20D manual, p.98, USING THE MULTI-SEGMENT METERING:
Quote: The center-weighted metering mode is automatically set even if you select the multi-segment metering mode when using a lens other than a DA, D FA, FA J, FA, or A lens, or when lens aperture ring is set at other than A.
A-type lenses support multi-segment (matrix) metering.
