12-24-2011, 06:34 PM   #1
GabrielFFontes's Avatar
Camera won't autofocus or take a picture with pop up flash
Hi guys. I bought my Pentax K-r camera 3 months ago, and i've been enjoying it since then, with no problems, but today (i only noticed it at christmas!!! ) i noticed that my camera won't autofocus and don't take the picture too with the pop up flash up.
If i close the flash, then the camera take the picture normally!
A couple of days ago (like 10 days i guess!), my friend took 3 photos with the pop up flash in a rapid succession...
What do yous guys think? It's broken?
Maybe it's time to buy an external flash, right? Already using this space, which external flash is the cheapest P-TTL one?
Thank you alot, and Happy Holidays!!!
12-24-2011, 07:49 PM   #2
Docrwm's Avatar
Hate to hear you're having trouble. Have you checked the flash settings both through the flash button on the back and the main menus?
12-24-2011, 09:12 PM   #3
hnikesch's Avatar
Do you have C menu item 16 set to off this will disable shutter release while flash is charging with maybe a low battery
Hans
12-25-2011, 02:12 AM   #4
calsan's Avatar
Sounds like the flash or flash circuit has blown. This can happen.
It's a new camera under warranty so take it back.
An external flash is a lot better, but you will still want the camera to work fully as the internal flash can be used to wirelessly trigger the external flash.
Plus you won't always carry the external flash with you once you get it.
12-25-2011, 07:15 AM   #5
Docrwm : Hate to hear you're having trouble. Have you checked the flash settings both through the flash button on the back and the main menus?
Yes, i checked everything tons of times , still nothing.
hnikesch : Do you have C menu item 16 set to off this will disable shutter release while flash is charging with maybe a low battery
Yes, i checked it. If i enable shutter release while flash is charging then the camera takes the picture, but without flash
calsan : Sounds like the flash or flash circuit has blown. This can happen.
Thank you all for the help
Unfortunately, i can't take my camera to warranty because i'm from Brazil, and there is no warranty here
Soo unlucky! oh my..
Well, i guess it's time to spend some money on an external flash instead of buying a new lens...
12-25-2011, 01:50 PM   #6
Hi guys. I'm sorry to double post, but i'm already on the process of choosing my first external flash.
I am probably going to buy a Metz 24 AF-1, but i have a question :
Is it possible that the problem on the flash also messed up with the external flash hot-shoe?
Because if it's not likely, then i'll start to search for this flash.
Thank you all
12-25-2011, 03:21 PM   #7
Philoslothical's Avatar
I don't think it's too likely that the hotshoe is damaged as well, but I don't think any of us could say for sure. Do you have a local camera shop that could do an off warranty repair? It might be worth getting a quote.
That's some really crappy luck you had, sorry to hear it. FWIW I don't think a few rapid shots with the flash would burn it out or damage it in any way, unless there was already a defect present. With mine the recharging time on the flash usually is self limiting. There was one thread about a guy who melted his K-7 flash, but he set it up on interval and took a LOT (in a misguided attempt to drain his battery). IIRC his still worked, it just had melted the casing around the flash tube.
12-26-2011, 05:00 PM   #8
I'll search for that, but it's very unlikely that i'll find a place to do Pentax warranty here...
Anyway, i'm less sad right now. I'm just searching for an external flash, and its going to be even better.
Thank you all so much for the precious help...
12-26-2011, 06:26 PM - 1 Like   #9
Elliot's Avatar
Pentax's Brazil service centers
Pentax UK lists three service centers in Brazil. They all seem to be in Sao Paulo. The site I found this listing is at
International Repairs - Central and South America - PENTAX Europe Imaging Systems
BRAZIL AP - Optical Brasil Ltda. Rua Dr. Renato Paes de Barros, 714 - Conj 103, Itaim Bibi - CEP 04530- 001, Sao Paulo +55-11-3071-3548
BMA COMERCIAL LTDA. Av. General Valdomiro de Lima, 896 Jabaquara - Sao Paulo - CEP.04344-070 +55 11 5011-0076
Central Repair Shop Rua 7 de Abril, 261 - 9 Andar - Sala 909 -Centro, CEP. 01043-000, Sao Paulo +55 11 3159-8850
01-02-2012, 11:51 AM   #10
Thank you guys alot!
I just noticed something today. If i pop up the flash, it still wont autofocus or take the picture, but the battery appears as fully charged. If i close it, it shows the actual battery status.
Do you guys know what this mean?
Also, i bought an AF280T, just waiting for it to be shipped...i hope it works normally...
01-02-2012, 02:13 PM   #11
Did you try resetting the camera defaults? I found two resets: "Reset Custom Functions" in the Setting menu, and "Reset" in the Setup menu.
I would also try downloading and re-installing the firmware.
01-02-2012, 02:44 PM   #12
Yes, i reseted the camera. No effect !
Updating my firmware is dangerous or something? Because i have no warranty here, so if something goes wrong, i'll be without my camera for a looooooooong time... For example, once my iphone died during firmware update, and it was easy to make it come back to life, but once my nokia died during the update, and i had to download like 10 programs to resuscitate it !
Thank you
01-02-2012, 04:26 PM   #13
As long as your battery is fully charged, and you follow the instructions exactly, it's pretty safe. There is a non-zero chance of something going wrong, but the same is true every time you pick up your camera (you could drop it). It takes a few minutes to complete. Never EVER get impatient and turn it off because you think it froze, or something like that.
I take it you haven't had any luck finding someone local to repair the flash eh? The issue with the battery level when the flash is activated is strange, I'm wondering if there's a short somewhere.
01-02-2012, 04:44 PM   #14
borno's Avatar
It sounds like a short in the flash circuitry to me also. My practically new k10d had a flash failure after about a dozen flash shots (in 2006) and shorted out the main circuit board. They replaced the body, so I guess you are lucky everything else works and a separate flash is so much better anyway.
01-28-2012, 10:39 AM   #15
Hi guys. You won't believe it : my AF280T arrived, defective!
It arrived 30 minutes ago, but i tried more than 10 different batteries, and it won't turn on. What do you guys think? Is there anything i should try? PS : I'm putting the batteries the right way :P
UPDATE
I made it work. I cleaned the battery contacts, put 1.5v batteries instead of rechargeable, turned it on and left it there for a couple of time. Then i heard a high pitch noise and it turned on.
autofocus, camera, days, flash, guys, k-r, kr, pentax k-r, picture, pop
K200D pop up flash won't close! lythari Pentax DSLR Discussion 7 03-02-2014 06:04 PM
K20D pop-up flash doesn't pop up! ducdao Pentax DSLR Discussion 3 11-29-2011 07:57 AM
Flash on K20D won't pop up, help skien68 Troubleshooting and Beginner Help 2 04-04-2011 12:50 PM
Help: Camera won't trigger flash Sofokle Pentax DSLR Discussion 2 05-30-2010 02:00 PM
Transmitters vs. pop-up for off-camera flash triggering marianne718 Troubleshooting and Beginner Help 12 07-13-2009 12:14 AM
All times are GMT -7. The time now is 01:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
