Originally posted by Darlene The SR is a savior of many of my shots. I wondered about the 14mm f/2.8, but it was more than "santa" could afford right now. I do have the 35mm f/2.4 as well.
You might consider the Tamron 10-24, not the fastest but at that focal range it needn't be. Price is under US$500 and there may still be a discount coupon active. It's not a huge lens (with the hood off) and I've used it for street from 15-24mm and for tight interiors from 10-16mm.
Originally posted by GabrielFFontes So, about that 1/FL shutter speed rule, i always calculate that the SR let us do speeds like 1/0,5*FL or even 1/0,25*FL easily!! For example, in my opinion, it isn't difficult to take pictures at 1/30 or 1/50 while using 200mm, or using the fifty to take pictures at 1/25, etc...again, just my opinion. Of course you cant count on that everytime...
It depends on your standard for acceptable sharpness. I have also shot 200mm handheld at 1/25 second but I don't expect crystal clarity there. For maximum handheld sharpness: f/8-f/11, SR on, 1/FL or faster. For acceptable sharpness: whatever works.
Originally posted by mattt I can say from most recent experience, having grown accustomed to FoV of 35mm on APS-C that the 21mm requires a much more... involved proximity. I love 35mm, its taking me some time to get used to 21mm - everything is so far away
I would expect that 15mm would require being even that much closer to fill a frame - I think I would find it even more uncomfortable. 300 mm from across the street is my comfort level right now tho
Wider glass is for getting closer. I'll use 15mm in crowds where I can hold the lens close to jam-packed faces. To shoot individual faces in not-so-jammed-up gatherings, I'll use 85-105-135mm lenses. To snipe passersby from a comfortable remove, it's a 300mm, or maybe the Lil'Bigma 170-500. And to shoot attendees at a mafiya funeral, I'd use the 1000/10 mirror from a safe distance, like 200m away.
