01-03-2012, 09:56 AM   #1
Tom Woj's Avatar
Burst/continuous shooting with remote?
Hi,
I'm pretty sure the answer is no, but is there some setting that I havnt noticed that allows you to hold down the remote and cause it to shoot in hi/low burst mode? (I'm using just a cheapo one button remote) From what I can see theres just the two setting's for remote trigger - either 'on press' or '3 sec delay' ...
Cheers,
Woj
01-03-2012, 10:23 AM   #2
RioRico's Avatar
I'm not sure with the Kr, but my K20D has a Continuous Remote setting in Drive Mode. In the Remote Control Shooting section of the user manual, it lists 1) instant shutter, 2) 3-second delay, and 3) continuous remote. I don't know if that's been disabled in the Kr. Check the manual. Good luck!
01-03-2012, 10:42 AM   #3
GabrielFFontes's Avatar
K-r doesn't isn't capable of that, i guess.
01-03-2012, 11:00 AM   #4
Tom Woj's Avatar
QuoteOriginally posted by GabrielFFontes Quote
Aye just double checked the manual. Can't do it. Well ... probably can do it, but they either couldn't be bothered to add it in the firmware or want you to upgrade
Shocking really, the camera can already sense when your holding the button down because you can use it on push/release for bulb mode start/stop. Why they couldn't add this in is beyond me.
01-03-2012, 11:51 AM   #5
Philoslothical's Avatar
You might be able to hack something for this yourself. There's a thread around about how to use an mp3 player to trigger the camera, like a normal remote. You make a lead with the IR diode on one end, headphone plug on the other. A sound file sends the correct pulse to trigger the camera. So... in theory, send out a whack of pulses pretty close together, and you might approximate continuous shooting.
01-03-2012, 12:42 PM   #6
RioRico's Avatar
Another trick is interval shooting, with the interval set to 1 second.
camera, k-r, kr, pentax k-r
K20d remote continuous shooting problem Subi Pentax DSLR Discussion 1 10-25-2011 05:55 PM
Can IR Remote be used for continuous shooting? mojoe_24 Pentax DSLR Discussion 11 07-13-2011 12:40 PM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
Continuous shooting fekish Pentax DSLR Discussion 8 09-24-2010 05:58 AM
K-7 Continuous Shooting brosen Pentax DSLR Discussion 17 08-29-2010 06:24 PM
All times are GMT -7. The time now is 10:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
